Raise Compression with Headgasket???
Old Sep 16, 2003 | 08:25 AM
VanHonda's Avatar
Default Raise Compression with Headgasket???
I have 9.0:1 wiseco pistons right now, but I'd like to raise the compression a bit for better driveability. I plan to run arounnd 10 psi daily and hopefully more in the future and at the track. What is a good thin headgasket that will hold up with boost?
Thanks,
Craig
Old Sep 16, 2003 | 08:35 AM
SpoolnG2's Avatar
Default Re: Raise Compression with Headgasket??? (VanHonda)
Cometic =
Old Sep 16, 2003 | 10:57 AM
VanHonda's Avatar
Default Re: Raise Compression with Headgasket??? (SpoolnG2)
Does Cometic make a thin gast to raise compression?
Old Sep 16, 2003 | 11:03 AM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VanHonda &raquo;</TD></TR><TR><TD CLASS="quote">Does Cometic make a thin gast to raise compression?</TD></TR></TABLE>
I was going to comment earlier to this, as far as I know the thinnest gasket is stock size at .030". But they may be able to custom make one according to Earl before on one of my posts. If you are stock bore then Spoon or Mugen is available.
Old Sep 16, 2003 | 11:07 AM
VanHonda's Avatar
Default Re: Raise Compression with Headgasket??? (Boostfed)
Would the Mugen hold the boost well at moderate levels?
Thanks
Old Sep 16, 2003 | 11:35 AM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VanHonda &raquo;</TD></TR><TR><TD CLASS="quote">Would the Mugen hold the boost well at moderate levels?
Thanks</TD></TR></TABLE>
As far as I know both gaskets are or possibly are stock gaskets with one layer taken out
tomlinson619
May 26, 2006 08:01 AM
g2turbo
Apr 18, 2005 04:00 AM
HondaRacer32
Jan 3, 2004 06:29 PM
genop
Sep 17, 2003 10:45 PM
FyReo3
Jun 5, 2003 11:18 PM
