oil catch can smokeing?
Old Oct 16, 2007 | 03:18 PM
boostedh22lude1's Avatar
Default oil catch can smokeing?
why is my oil catch can smokeing?
Old Oct 16, 2007 | 03:29 PM
DC2-KING's Avatar
Default Re: oil catch can smokeing? (boostedh22lude1)
Bad Rings.
Old Oct 16, 2007 | 04:07 PM
Default Re: oil catch can smokeing? (DC2-KING)
bump
Old Oct 16, 2007 | 04:11 PM
Jockobo's Avatar
Bad Rings.
Old Oct 16, 2007 | 04:13 PM
Default Re: oil catch can smokeing? (Jockobo)
my compression is 185 acros the bord
Old Oct 16, 2007 | 05:06 PM
d15bfi's Avatar
i get the same ****. About the same compression numbers as well. Have heard mixed answers about this question...
Old Oct 16, 2007 | 05:08 PM
Default Re: oil catch can smokeing? (d15bfi)
so then whats up with it?
Old Oct 16, 2007 | 05:11 PM
kuja's Avatar
shouldn't have asked.. everyones gonna say bad ringlands. How much smoke? A little is normal. Mine's steamed a little ever since i installed it 2 years ago, about 20 dyno pulls, 10 track days, 14psi of daily beatings later, yea it must be my broken yet invincible ringlands.
u'll be fine if your really concerned do a leakdown test.
Old Oct 16, 2007 | 06:50 PM
DaveF's Avatar
Default Re: oil catch can smokeing? (kuja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the herd &raquo;</TD></TR><TR><TD CLASS="quote">Bad Rings.</TD></TR></TABLE>
thats what this guy thought
Old Oct 16, 2007 | 06:52 PM
alterdcreations's Avatar
Default Re: oil catch can smokeing? (DaveF)
mine was smoking and i ended up with a spun main
Old Oct 16, 2007 | 07:51 PM
integranator's Avatar
Default Re: oil catch can smokeing? (alterdcreations)
mine just smokes under wot pulls. Compression checks in at 190 across the board on the built motor. Not quite sure what that means though.
Old Oct 16, 2007 | 09:22 PM
kuja's Avatar
yea but thats an eclipse
Old Oct 17, 2007 | 01:35 AM
welfarepc's Avatar
when my rod snapped and cracked/punctured my block i poped my hood and there was thick white lingering smoke coming from the crank vent system. the motor also had 1 piston with 130 compression that had bad rings...
Old Oct 17, 2007 | 04:00 AM
twkdCD595's Avatar
Default Re: (welfarepc)
When my valve cover breather was pushing a little smoke out of it, it was after a hard run and the wastegate line worked itself loose... causing a pretty bad boost spike. Ended up being a blown headgasket... mine was more sweet smelling steam though than it was smoke. It was also obvious that they headgasket was a problem cause my car sounded like a subby.
I have noticed that on a cars with vented crankcases or catch cans a little puff of steam right after a cold startup is nothing more than condensation... thats about the only other time I see a bit of vapor come from the breather, that it has not been something more serious or bad.
Old Oct 17, 2007 | 10:40 AM
advert's Avatar
mine smokes on WOT a little. i never thot to much of it. hmm.
Old Oct 24, 2007 | 02:01 AM
zum78spd's Avatar
My Evo used to do that, it's normal, it's not smoke but condensation. If it's not steaming hot, get close to it and smell it, it's just steam...
nekoabandoned
Jul 24, 2006 03:39 PM
EF'n Sedan
Mar 15, 2006 08:37 AM
mike93eh
21
Sep 18, 2005 12:23 PM
cgap
Jun 18, 2004 01:15 AM
aut0tek
Apr 10, 2004 08:30 PM
