quick turbo timer question
Old Jun 29, 2003 | 08:07 PM
tek_civic's Avatar
Default quick turbo timer question
ok so assuming i have a turbo timer installed on my car, then go drive it hard and park it, it or i tell it how long the car should stay on for after i remove the key right? my question is during that time when the key is out but the car is running, what is there to stop the car from being driven? tnx
Old Jun 29, 2003 | 08:10 PM
GSRrR's Avatar
Default Re: quick turbo timer question (tek_civic)
on the greddy TT, it has a wire going to your brake handle and 1 to the ecu(speed sensor). if the parking brakes are released or if they car moves, the TT shuts off the engine.
Old Jun 29, 2003 | 08:37 PM
TurboDX's Avatar
Default Re: quick turbo timer question (GSRrR)
the hks is the same way....it isnt like your car runs for five minutes or anything....driving hard around town the most i have seen is 2mins....hope this helps...
Old Jun 29, 2003 | 09:08 PM
tek_civic's Avatar
Default Re: quick turbo timer question (TurboDX)
tnx a bunch, i had a feeling it was something like that i was just curious. is there much of a dif between timers? besides being auto/manual?
Old Jun 30, 2003 | 05:19 AM
PM-Performance's Avatar
on the HKS it will shut off when the ebrake is put down , or the car goes in gear, other thna that i lock my steering wheel anyway , im scared since it cant go in gear it might roll or something , so i lock the wheel.
Old Jun 30, 2003 | 06:22 AM
Spudddy's Avatar
which wire on a 00 si ecu is the vss?
Old Jun 30, 2003 | 06:26 AM
Default Re: (Spudddy)
look at your ecu pinout. thats the way i did it .
Old Jun 30, 2003 | 07:36 AM
ARACER25's Avatar
The Apexi works the same way plus it has an A/F reading that I like. It is also small as hell like a pen. Can mount it anywhere.
Old Jun 30, 2003 | 10:30 AM
Muckman's Avatar
Moderator in Chief
Default Re: quick turbo timer question (ARACER25)
can u hook up a Wideband O2 to that Apex tubro timer to display a AFR reading? Im getting the AEM WB O2 for my EMS. I might as well get the Apex TT if I can hook the two up
Old Jun 30, 2003 | 08:17 PM
ARACER25's Avatar
That I am not sure. I know it hooks up to the first O2 sen but I don't really know anything about wideband.
Old Jun 30, 2003 | 09:49 PM
JDEM1's Avatar
Default Re: (ARACER25)
not to jack your thread or anything.. but then what the hell do you do when you part on a hill if you cant leave it in first gear?
Old Jun 30, 2003 | 09:53 PM
JMinSi2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spudddy &raquo;</TD></TR><TR><TD CLASS="quote">which wire on a 00 si ecu is the vss?</TD></TR></TABLE>
Its a blue/white wire coming out from behind the guage cluster.
Old Jun 30, 2003 | 09:55 PM
MiraiZ's Avatar
Default Re: (JDEM1)
you should be able to put it in gear...as long as the e-brake handel is up, the TT will continue to count down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDEM1 &raquo;</TD></TR><TR><TD CLASS="quote">not to jack your thread or anything.. but then what the hell do you do when you part on a hill if you cant leave it in first gear? </TD></TR></TABLE>
Old Jun 30, 2003 | 10:00 PM
88ZCRX's Avatar
Default Re: (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to put it in gear...as long as the e-brake handel is up, the TT will continue to count down.
How do you leave a car in gear and on at the same time without going anywhere?
Old Jun 30, 2003 | 10:09 PM
avex's Avatar
Default Re: (88ZCRX)
that's what rocks are for just set a rock on the clutch pedal and you're set haha
Old Jun 30, 2003 | 10:52 PM
TurboTeG4's Avatar
Default Re: (avex)
What happens when your car dies out on the hill or I mean the timer obviously cant keep the engine running if its in gear or will it will sense it and idle in gear? And if you decide to go and cancel the turbo timer what do u do just put ur key to acc and off u go. Lot of unanswerd questions in my mind about the little device.
Hope u dont mind my post
Old Jun 30, 2003 | 11:13 PM
avex's Avatar
Default Re: (turbocivic4)
the timer can't sense and idle it in gear. I guess people who park up on hills are screwed. You can cancel the countdown by just putting the key in the ignition, and turn the key until you're just about to start the car. you can drive off now , the timer will shutdown but hte key will keep the car from shutting off. This works with the greddy tt , i dunno about the others.
Old Jul 1, 2003 | 09:23 AM
M-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to put it in gear...as long as the e-brake handel is up, the TT will continue to count down.</TD></TR></TABLE>
That's got to be one of the wackiest things I've heard on here. No, you cannot leave the car in gear if it's running on a turbo timer. Not even if the e-brake is up (WTF?).
Anyway, I've learned to trust my e-brake for parking on hills (that and I turn the wheels to the curb if there is one and lock the steering wheel). If it's really a steep hill or an odd location, I disable the countdown and just leave my car in gear with the e-brake pulled.
Old Jul 2, 2003 | 09:10 AM
Muckman's Avatar
Moderator in Chief
Default Re:
Simple - Just make sure your E-brake works like it should and u dont need to put it in gear.
Old Jul 2, 2003 | 02:14 PM
MiraiZ's Avatar
</TD></TR></TABLE> Okay okay ...I didn't think about htis much before I typed it
ANYWAYS, I always just turn my steering wheel into the curb when parked on a hill. Otherwise, in the situations when you are on a hill, stay with the car and shut it off manully, then put it into gear...better?
Old Jul 2, 2003 | 06:15 PM
JDEM1's Avatar
thanks for the replies...
blinger
May 23, 2007 08:07 PM
1baddturbosi
Dec 15, 2006 08:55 PM
Goldfingiz
Aug 16, 2003 08:28 AM
Mugen_Power
Jan 8, 2003 04:25 PM
