Some issues with turbo timer.
Old Aug 15, 2003 | 09:46 AM
Goldfingiz's Avatar
Default Some issues with turbo timer.
Hey guys I picked up a Greddy turbo timer and just installed it. I noticed that the minutes will keep going up as I'm driving. By minutes I mean the number of minutes the car should stay on after I remove the key. It goes up to about 6 or 7 minutes. Also, I connected it to the speed sensor wire going to my ECU, but the km/h are way off. Any idea what this could be?
Thanks!
Old Aug 15, 2003 | 02:04 PM
VisualAutoMotoring's Avatar
Default Re: Some issues with turbo timer. (Goldfingiz)
i believe that's a built in feature from the auto timer...it calculates the amount of time you have driven so when you shut your car off, it will cool it down for the equivalent time....
you can just turn that feature off
Old Aug 15, 2003 | 04:20 PM
Yosshaa's Avatar
^^^i'm wit stupid.
as for part 2 check your wires!
Old Aug 15, 2003 | 05:04 PM
Default Re: (ambition)
who are u callin stupid???
Old Aug 15, 2003 | 05:52 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (PRojectSi2)
i dont know about the greddy but my apexi you can set the highist and lowest settings
Old Aug 15, 2003 | 05:59 PM
tek_civic's Avatar
Default Re: (TURSpoonEK)
ya there should be a manual mode too, if i drive around a little i usually keep it at .5 to 1 min but if im redline running i will set more. also its not really necessary to let it cool down while your getting gas or anything quick like that as the oil will not have enough time to coke and clogg your lines and ports.
Old Aug 16, 2003 | 08:28 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (tek_civic)
there should be a quik turn off function on yours , ill refer back to my apexi , you flick the button to the left or right when the engine is timing out , in one sec it will turn off
Apr 2, 2005 12:08 AM
B00STED Si
Jan 24, 2005 07:53 PM
alfee
Jan 4, 2005 11:02 PM
Hoosier Daddy
Feb 25, 2004 06:56 PM
whiteblurr
Feb 24, 2004 10:54 AM
