quick turbo question
Old Apr 14, 2004 | 08:47 AM
ACrite3404's Avatar
Default quick turbo question
I have a b18 motor wit civic SIR pistons in it and was wondering would it be ok if i run greddy 18g turbo w/ intercooler on it or should i jus put the integra pistons bac in? and im only goin to be pushing bout 6-7psi.
thanx
mike
Old Apr 14, 2004 | 09:06 AM
BEV@GSCMotorsports's Avatar
Default Re: quick turbo question (ACrite3404)
which integra pistons do you have? If you've got LS pistons i would use them because they are lower compression. just be sure to be careful with the higher compression and turbo. Detonation will ruin your engine before you know it!
Old Apr 14, 2004 | 09:24 AM
blown_LS's Avatar
Default Re: quick turbo question (CivicTurbo12)
You will be fine with those pistons as long as you get the car tuned right. If you are gonna run some crapy fmu then swap those ls pistons back in. If goin for better fuel management then keep the sir pistons. Just remember more compression will give you power but less margin for error.
Old Apr 14, 2004 | 10:11 AM
ACrite3404's Avatar
Default Re: quick turbo question (blown_LS)
ok thanx fellas
Old Apr 14, 2004 | 10:20 AM
ACrite3404's Avatar
i have Ls pistons. i was wondering since the Ls pistons r lower compression shouldnt i use them?
Old Apr 14, 2004 | 11:12 AM
using the LS piston would be safer, and like he said. more margin for error.
Old Apr 15, 2004 | 03:05 PM
ACrite3404's Avatar
if im runnig a greddy g18 turbo kit with intercooler and apex i exhaust what extras would i need for the turbo to work correctly.
Old Apr 15, 2004 | 03:07 PM
ACrite3404's Avatar
its a stock ls motor
recon23
Nov 6, 2007 04:50 AM
chamorru67
Feb 25, 2007 05:38 PM
ekVtecPower
Jun 18, 2006 09:05 PM
redDAinteg
Jun 19, 2005 05:58 PM
gassaversracing
Feb 11, 2005 02:54 AM
