question about pistons
Old Feb 10, 2005 | 10:56 PM
gassaversracing's Avatar
Default question about pistons
i was wondering about forged pistons. if i get 9.2:1 forged pistons, staying stock compression in an LS, does that add horsepower or just more reliable pistons?
Old Feb 10, 2005 | 11:02 PM
FLOWZILLA's Avatar
Default Re: question about pistons (gassaversracing)
some pistons have been known to make alittlt more power but dont expect a huge gain from them . the reason they make any power is because they a have a better flame travel design and because of wieght ..which pistons are you planning on getting ?
Old Feb 10, 2005 | 11:06 PM
Default Re: question about pistons (FLOWZILLA)
i dont have any in mind. im saving for an LS swap, and would like to get about 200hp to the wheels SAFELY on motor. then i'll be happy with it. that would put me 8.7ish i think. if its not dependable to run high 8s, i dont wanna do it. would forged rods and pistons be necessary for that? if not, what mods would?
Old Feb 10, 2005 | 11:15 PM
this is the first car i'm doing this with btw. i know theres quite a few civics with the LS in them and just want a guideline sort of.
FLOWZILLA's Avatar
200 hp on stock compression is very doubtful you may want to raise it a bit . i carry arias and the only thing that is available off the shelf is 9.9:1 @81.5 bore or 12:1 @81.5 bore 12:1 is just a tad bit to much but with a thicker gasket it would be perfect for what you need. rods are'nt necessary but would be nice. you will also want to look into cams head work and a management system. give me a call i can supply you with everything you need .
Old Feb 10, 2005 | 11:18 PM
well i got a guy about 45 minutes from me that could have the 1.5 out and the LS running in about 4 hours. does swaps all the time. just dont wanna bug him with questions til i have money to do it.
Old Feb 11, 2005 | 02:54 AM
non-VTEC's Avatar
taking out your stock 9.2:1 pistons and putting in a set of forged 9.2:1 pistons is pointless. it wont increase your power output at all.......
you want more compression for more power. select a piston with the highest avalible octane fuel avalible in your area. im sure everyone will recommend a minium of 11:1 which can easily be run on 91 octane.
Beasting EF22
Jan 14, 2012 05:48 AM
94-integra-ls
May 12, 2008 09:11 PM
wesley_925
Mar 31, 2008 08:44 AM
jdm.ej
May 9, 2005 03:19 PM
TurboT
Nov 28, 2001 01:42 PM
