quick sohc question
Old Dec 27, 2005 | 08:12 PM
ekslax's Avatar
Default quick sohc question
just curious to know, how much boost can a d16z6 hold without blowing. Stock block no internals, no tuning, just stock d16z6 and a turbo kit. how much is safe and reliable to run on that motor.
and also how much stronger do stock pistons and rods get when they are shot peened, or what ever its called. thanks in advance
Old Dec 27, 2005 | 08:18 PM
nonvtecD's Avatar
you get the crappy post of the day award, how much boost can it handle without tuning? none
Old Dec 27, 2005 | 08:25 PM
willyboyK20's Avatar
Default Re: quick sohc question (ekslax)
Well to answer your first question you can't really ask how much boost and engine can hold, a better question is how much horsepower it can hold because 10 psi on a t25 is not the same power as 10 psi on a t3/t4.
With our single slammers the gen hp rating is around 200-250whp, with 250 pushing it. These numbers are based on "A GOOD TUNE"!!! Without tuning then don't expect much out of any non-turboed factory engine.
About the shot peening I know they increase the engine rod's stress levels but I don't know the effect on pistons.
Old Dec 27, 2005 | 08:35 PM
ekslax's Avatar
Default Re: (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">you get the crappy post of the day award, how much boost can it handle without tuning? none</TD></TR></TABLE>
jackass, im sure a singlecam can hold some sort of boost, im not asking about alot of boost, im sure it can take 5psi daily with out any problem.
Old Dec 27, 2005 | 08:36 PM
nonvtecD's Avatar
You don't shotpeen pistons, period. And shotpeening a stock sohc rod will net you negligable gains in strength.
Old Dec 27, 2005 | 08:37 PM
EVIL Hx Coupe's Avatar
Default Re: (ekslax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekslax &raquo;</TD></TR><TR><TD CLASS="quote">jackass, im sure a singlecam can hold some sort of boost, im not asking about alot of boost, im sure it can take 5psi daily with out any problem. </TD></TR></TABLE>
Actually with 5 psi and no tune the car is going to be pretty slow and shitty. So might as well skip turbo all together if you're not going to do it right.
Old Dec 27, 2005 | 08:39 PM
ekslax's Avatar
Default Re: (EVIL Hx Coupe)
but i didnt ask you all that,
Old Dec 27, 2005 | 08:41 PM
ekslax's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL Hx Coupe &raquo;</TD></TR><TR><TD CLASS="quote">
Actually with 5 psi and no tune the car is going to be pretty slow and shitty</TD></TR></TABLE>
will it be reliable and will it run safely is what im asking, not your opinion if its worth it.
Old Dec 27, 2005 | 08:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekslax &raquo;</TD></TR><TR><TD CLASS="quote">but i didnt ask you all that
will it be reliable and will it run safely is what im asking, not your opinion if its worth it. </TD></TR></TABLE>
An untuned car wont be reliable. An untuned/basemap car should be carefully driven straight to the tuner, or if you must drive it then you should try to stay out of boost for the motor's sake.
Old Dec 27, 2005 | 09:32 PM
wpgcivic's Avatar
brother made 264 wheel 200 tq stock z6 tuned with uber, sc50 13 psi
Old Dec 27, 2005 | 09:39 PM
Default Re: (wpgcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic &raquo;</TD></TR><TR><TD CLASS="quote">brother made 264 wheel 200 tq stock z6 tuned with uber, sc50 13 psi</TD></TR></TABLE>
eastbay92cx
Aug 4, 2007 09:11 AM
hold your breath
Feb 7, 2007 12:36 PM
megotvtec
Aug 13, 2004 01:10 PM
crzyfool24
Feb 7, 2004 05:24 PM
99SilverEx
Jul 6, 2002 11:28 AM
