Quick Revhard Manifold ?
Old Jan 6, 2003 | 01:14 AM
SweetChin's Avatar
Default Quick Revhard Manifold ?
well im about to order a revhard stage 2c kit but im not sure which manifold to get...i was thinking about upgrading to the tubular manifold but the shop im ordering from says they are prone to cracking in a year or 2...
the kit is goin in a 92 teg with a b18c swap...i dont really race and only plan to run low boost(under 10psi).
what do you guys think i should get?
Old Jan 6, 2003 | 01:24 AM
turbohonda's Avatar
Default Re: Quick Revhard Manifold ? (SweetChin)
Stick with the cast manifold if it is going to be a low boost street car. They are good to well over 400 wheel hp. Most manifolds that aren't cast (like stainless or mild steel) will eventually crack if driven everyday.
Arturbo's Avatar
Better than steak
25 Year Member
All manifolds are prone to cracking, but I would get the cast iron one. Just make sure you use a flex pipe on your downpipe and keep moisture off of the manifold.
art
PolyPill
Sep 11, 2012 10:35 PM
therunnerz
Jun 4, 2009 08:54 PM
lsvsol
May 14, 2006 06:35 AM
eg2turbo
Oct 31, 2003 07:49 PM
W.Zero
Aug 26, 2002 05:09 PM
