Quick Question.....Should i Boost with over 100k miles?
Old Sep 15, 2006 | 09:43 PM
JustHere4ADay's Avatar
WHEEL Slayer
Default Quick Question.....Should i Boost with over 100k miles?
I just broke 100k miles and i wanted to put a rev hard kit on my 02 si....Just dont know if its safer just to swap it out or what......
Old Sep 15, 2006 | 09:44 PM
EK k kay's Avatar
Default Re: Quick Question.....Should i Boost with over 100k miles? (JustHere4ADay)
I boosted on 105k.
Old Sep 15, 2006 | 10:30 PM
ProjectDarkBlack's Avatar
Default Re: Quick Question.....Should i Boost with over 100k miles? (EK k kay)
yes....use K-pro though. My teg is 125xxx on the stock block on 9-10psi and lovin it
Old Sep 15, 2006 | 11:25 PM
Ti3d in's Avatar
Default Re: Quick Question.....Should i Boost with over 100k miles? (ProjectDarkBlack)
As long as it was taken care of and the compression is good, it should be fine. I boosted my teg at 135k.
Old Sep 16, 2006 | 12:00 AM
srg's Avatar
srg
I've boosted del sol si with 250,000.00 KM's. The only one thing happend week later was blow'n headgasket.. and that's because of my bad tune
Old Sep 16, 2006 | 04:09 AM
boostedcivicsir's Avatar
Mr. Badwrench
compression and leakdown..........ok.........boost away.
Old Sep 16, 2006 | 08:10 PM
red93accord's Avatar
I'm a Jackass
not on a k-series, happened to my buddies non type-s and two cylinders are way down on comp.
Old Sep 16, 2006 | 11:30 PM
btech's Avatar
Default Re: (red93accord)
im boostin at 205xxx... just replaced my headgasket and was good to go..
but i just got some new piston, rings and rod... gonna spend some more $$$.. should of done everything all at once..
prolly should get a new racing clutch too.
Old Sep 16, 2006 | 11:41 PM
NFSUTuner's Avatar
Default Re: (btech)
Hey Check out my RPG Invite!!! (See the Accord forums...."Street Racing RPG!!"
Old Sep 17, 2006 | 08:26 AM
mrlegoman's Avatar
Default Re: (NFSUTuner)
If you planning on running 6-8psi, go for it. But anything over would recommend a rebuild.
Wayne_Curr
Oct 20, 2005 04:41 PM
Garbonzon311
Jan 26, 2004 10:54 PM
NVMYSi
Jun 24, 2003 09:51 AM
RicerRacing69
Dec 7, 2002 07:28 PM
