High Mileage with Boost
Old Dec 7, 2002 | 03:51 PM
RicerRacing69's Avatar
Default High Mileage with Boost
Today I took my B18B longblock out and am beginning the rebuild. I Bought a B18A long block off of a friend for $350 for a temporary swap in my teg. The swap has 155,XXX miles on it and he did alittle street racing with it and had I/H/E. Maintenance was kept up ok from what I understand.
Now my question is would I be able to run 7psi on it for about 6 months or so? It will have everything on my old setup in my sig except the port&polish and n20 and it will be tuned. I only had 37K on my old set up, and I don't know the affect of boost on high mileage engines.
Old Dec 7, 2002 | 07:28 PM
Broken Gearbox's Avatar
Default Re: High Mileage with Boost (RicerRacing69)
first you should drop the motor in and see how it runs...if it runs pretty good turbo it...if its a little sluggish ...go get a compression test..ask your friend if the motor was in good shape before he took it out..
SillEG8ferio
17
Nov 10, 2010 07:28 PM
DELshow
Apr 28, 2006 06:55 AM
