Quick Question.....Should i Boost with over 100k miles?
I just broke 100k miles and i wanted to put a rev hard kit on my 02 si....Just dont know if its safer just to swap it out or what......
Re: Quick Question.....Should i Boost with over 100k miles? (JustHere4ADay)
I boosted on 105k.
Re: Quick Question.....Should i Boost with over 100k miles? (EK k kay)
yes....use K-pro though. My teg is 125xxx on the stock block on 9-10psi and lovin it
Re: Quick Question.....Should i Boost with over 100k miles? (ProjectDarkBlack)
As long as it was taken care of and the compression is good, it should be fine. I boosted my teg at 135k.
I've boosted del sol si with 250,000.00 KM's. The only one thing happend week later was blow'n headgasket.. and that's because of my bad tune https://honda-tech.com/forums/images...es/emsmile.gif
compression and leakdown..........ok.........boost away.
not on a k-series, happened to my buddies non type-s and two cylinders are way down on comp.
Re: (red93accord)
im boostin at 205xxx... just replaced my headgasket and was good to go..
but i just got some new piston, rings and rod... gonna spend some more $$$.. should of done everything all at once.. prolly should get a new racing clutch too. |
Re: (btech)
Hey Check out my RPG Invite!!! (See the Accord forums...."Street Racing RPG!!"
Re: (NFSUTuner)
If you planning on running 6-8psi, go for it. But anything over would recommend a rebuild.
