Quick Question...Re-using Headgasket...
Old Oct 27, 2005 | 01:59 PM
m R g S r's Avatar
Default Quick Question...Re-using Headgasket...
I just assembled my motor (LS-V) to find out that the bottom end is no good. (low on compression)
Can I re-use the headgasket (It was brand new, oem LS) after I pull it off? I didn't run the motor, didn't even fill it with coolant or oil.....
Thanks
Old Oct 27, 2005 | 02:04 PM
mike1114's Avatar
Default Re: Quick Question...Re-using Headgasket... (m R g S r)
no. I think that's the reason I blew my headgasket.
Old Oct 27, 2005 | 02:19 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Quick Question...Re-using Headgasket... (mike1114)
once they are squashed they cant seal correctly on another engine.
Old Oct 27, 2005 | 03:50 PM
hondaguyef's Avatar
Default Re: Quick Question...Re-using Headgasket... (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">once they are squashed they cant seal correctly on another engine.</TD></TR></TABLE>
Exactly, They are crush style gaskets and do not seal properly after being torqued once. It sucks and I have just recently been though the same situation as you (bad bottom end) but, you gotta do it right and buy a new gasket.
Phil
Old Oct 27, 2005 | 04:02 PM
HiProfile's Avatar
Default Re: Quick Question...Re-using Headgasket... (hondaguyef)
If its very low boost, I'd say yes if you spray it with that copper stuff. Otherwise...no. As proof that reusing it is okay for NA, my z6 pulled a perfect 200psi with my brother's Snap-On comp tester. I reused the OEM HG, actually used thin film of copper impregnated silicone (hell, it worked on all those V8's I did) due to not having the spray. Has 1k miles on it since it was reassembled (reusing oem headbolts), and I'm rather hard on it.
BTW why wouldn't you replace the bearings and rings when doing LS/VTEC? Its the least you can do to spin it past 7500 reliably.
Old Oct 27, 2005 | 04:03 PM
m R g S r's Avatar
Ouch...thats rough. Thats what I thought, just wanted to be sure. What a friggen waste of money. Anyway, thanks guys.
Old Oct 27, 2005 | 05:09 PM
DRAGLS's Avatar
Yes you can still use the gasket.
Old Oct 27, 2005 | 06:17 PM
m R g S r's Avatar
Default Re: Quick Question...Re-using Headgasket... (DRAGLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS &raquo;</TD></TR><TR><TD CLASS="quote">Yes you can still use the gasket.</TD></TR></TABLE>
lol....umm....alright
im not gonna use it....i was pretty sure it was a crush style gasket, just not positive. and my plans are now for alot of boost cuz im building the motor lol
Old Oct 27, 2005 | 06:33 PM
rhd's Avatar
rhd
it's cool to reuse in a normal situation (low boost or n/a) just copper spray both sides....but, it should just be a temp thing until you can get a new one in hand
Old Oct 27, 2005 | 06:53 PM
m R g S r's Avatar
Default Re: (rhd)
iite...new one it is
Old Oct 27, 2005 | 08:21 PM
astig* DC2's Avatar
Default Re: (m R g S r)
iouno..i got this line from sumone else's "reusing a HEADGASKET is like reusing a CONDOM"
Old Oct 27, 2005 | 08:35 PM
White_EK49's Avatar
i reuse my hg and it's going strong. it's for NA not FI. hope that helps. i am a cheap bastard to a certain extent.
Old Oct 27, 2005 | 08:39 PM
astig* DC2's Avatar
Default Re: Quick Question...Re-using Headgasket... (slow29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow29 &raquo;</TD></TR><TR><TD CLASS="quote">i reuse my hg and it's going strong. it's for NA not FI. hope that helps. i am a cheap bastard to a certain extent.</TD></TR></TABLE>
lolz..your like me..CHEAP... when it comes to parts..
NguyenDC2
Dec 16, 2007 09:42 PM
TwoKSiR
Jul 31, 2006 11:50 PM
D-series ninja
Sep 18, 2005 09:54 PM
99CivicExCoupe
Sep 11, 2004 09:08 PM
TurboJesse
Jan 23, 2004 02:34 PM
