Quick question about LS block
Old Nov 4, 2006 | 07:14 AM
drewbie's Avatar
Default Quick question about LS block
I have the chance to get a good deal on a LS motor.
I was just wondering what kind of boost can be ran safely on the stock block?
I searched, but all I found was turbo kits
Old Nov 4, 2006 | 07:21 AM
TunerShark's Avatar
Default Re: Quick question about LS block (drewbie)
i might be wrong but your stock MAP sensor shouldnt allow you to run more than 11, but if you get a 3-bar you can run alot more, motor wise i dont know, because i dont know anything about LS motors.
Old Nov 4, 2006 | 08:59 AM
50SaysHeEatsIt's Avatar
Default Re: Quick question about LS block (TunerShark)
Yes,using a 3 bar map sensor will open the door to more boost. I would say on a stock ls that has good compression you can get 300 whp with about 14-16lbs. But I would not drive with that boost up there everyday on a stock motor.
Ls motors do good with boost and make good tourqe as well and im sure others will post up and say "its all in the tune" Because it is ...you have to have a tuner you trust to make good conservative power there is a LS-T thread you should check out ...there is more that 300 pages of good info on there
https://honda-tech.com/zero...85196
check it out do some reading and searching and im sure you can find out what you would like do Good Luck
dantamparacer
May 17, 2010 04:31 PM
fireblaze2k1
Mar 14, 2009 03:15 AM
b00stedda
Nov 10, 2007 09:34 PM
crxsteve
Nov 18, 2006 06:41 AM
a2dadamm
Dec 30, 2005 02:30 PM
