quick question about injectors
I have a quick question about injectors...I dont want to run a resistor box...if i use Precision turbo and engine 525cc Honda Style Injectors (Top Feed) will i still have to run a resistor box? part number on these injectors is 042-0525..........thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 »</TD></TR><TR><TD CLASS="quote">No you would not have to run a resistor box. Those are saturated injectors. </TD></TR></TABLE>
/thread
/thread
SO they would "wire" directly so to speak? plug and play
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 »</TD></TR><TR><TD CLASS="quote">?</TD></TR></TABLE>
are you confused about something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSej1 »</TD></TR><TR><TD CLASS="quote">
SO they would "wire" directly so to speak? plug and play</TD></TR></TABLE>
well it would have been helpful if you told us your setup from the start but from your sig and username ill assume you are obd1 so these injectors should plug and plug, no problem.
Yes I am confused about something. I didnt understand what " /thread" meant.
And you do not need a resistor box. The amount of resistance in your system is the same as the 525cc injectors you want to purchase.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 »</TD></TR><TR><TD CLASS="quote">I didnt understand what " /thread" meant. </TD></TR></TABLE>
the "/" is html code to end or stop something. so by dpetro1 quoting you saying "/thread" pretty much means you answered the OPs question and there is no point to keep this thread going..well unless the OP has any more questions of course lol.
Sassafrass
Oct 9, 2004 09:58 PM
