quick question about boost pressure
Old Jul 18, 2007 | 05:07 PM
InTeGrA_bLazEd's Avatar
Default quick question about boost pressure
i have a drag gen 3 turbo on my LS. i had to take apart and reassemble the downpipe, turbo and manifold due to loose bolts. i just finished putting it all back together and i have the car on jack stands. none of the wheels are touching the ground. i decided to test out the boost pressure and check from my gauge. will the car not being on the ground cause the car to not build any boost? reason is i just tried and the gauge does not read past 0 psi at all. im hoping there's not another problem with my turbo. i dont think i missed any reinstallation parts. i double checked to make sure everything was connected. so anyone with any experience on this, please help.
Old Jul 18, 2007 | 05:17 PM
poop II's Avatar
Default Re: quick question about boost pressure (InTeGrA_bLazEd)
93
If I understand you correctly, you tried building boost by reving the car out with the wheels off the ground? A bit dangerous, but nonetheless, an engine needs to be under a load to expend the energy for a turbo to make positive boost pressure. They are not rpm dependant. A few cars might have made boost, but most would just go up to 0 psi or low vacuum.
93 93/93
Old Jul 18, 2007 | 05:32 PM
Default Re: quick question about boost pressure (poop II)
ok, so even if the car is in gear but wheels are not on the ground, it wont build boost then. correct?
Old Jul 18, 2007 | 05:39 PM
wrayzor's Avatar
no the engine has to be under load to build positive boost pressure like he said above
Old Jul 18, 2007 | 05:44 PM
thanks guys. i got worried for a little. i hope everything goes right from now on......
mony725
May 7, 2009 06:58 PM
mountainmonkey
Aug 1, 2006 04:46 AM
3k9civic
Oct 3, 2005 12:02 AM
genop
Mar 31, 2003 06:04 PM
