not getting boost need help
Old May 7, 2009 | 06:30 AM
mony725's Avatar
Default not getting boost need help
ok im kind of new to the whole turbo setup and ive been doing alot of research and i have everything all setup in my car i have a t4 60trim turbo with a top mount on my ls with an external WG i checked for boost leaks found a couple and got them all squared away but im still not hitting boosted im not sure what is wrong could it be the WG it 10 psi spring and im not sure if it has to be ajusted or how to do it
if anyone has input let me know the turbo is brand new so its not blown
Old May 7, 2009 | 06:38 AM
ryanhauk's Avatar
Default Re: not getting boost need help
well. so you have a boost gauge?
Old May 7, 2009 | 09:22 AM
mony725's Avatar
Yes I have a boost guage it reads.vac and when I go to boost reads 0 and sometimes 1
Old May 7, 2009 | 12:47 PM
Silva Bullit DC4's Avatar
Are you driving the car, or free revving at a standstill?
Old May 7, 2009 | 02:53 PM
mony725's Avatar
its on jack stands i have it in 2nd and i hold the breaks to put pressure on the wheels but still even at free rev why wouldnt it boost
Old May 7, 2009 | 02:58 PM
hondabigblock's Avatar
a t4 isnt going to spool unless you have it under a load. Holding the breaks and reving your motor isnt going to make it spool
Old May 7, 2009 | 03:01 PM
Robert Padron's Avatar
WOW, it's never going to build any readable boost on jackstands. There has to be a load on the motor, like the car being driven full throttle. DRIVEN, not on jack stands.
Old May 7, 2009 | 03:04 PM
mony725's Avatar
so you think the turbo is too big
Old May 7, 2009 | 03:16 PM
thats a big turbo for a stock motor. what is your power goals ? Is this motor bone stock ?
Old May 7, 2009 | 03:24 PM
mony725's Avatar
yea its stock i wanna run 12 psi i got it cheap so i was like whatever and threw it on
Old May 7, 2009 | 06:00 PM
b20beast83's Avatar
you need to drive it like everyone said
Old May 7, 2009 | 06:58 PM
Dont set a psi goal, set a power goal. Your tuner will use whatever psi your setup will give him to make that goal.
What motor is it? Post your setup.
DntFk_jdm
Nov 2, 2015 03:19 PM
MatthewMenze
Oct 23, 2013 09:06 PM
honkey2fly
May 15, 2004 10:32 AM
r1lorenzini
Feb 19, 2004 11:54 AM
Integra187
Sep 21, 2001 07:13 PM
