Quick 2.5" exhaust ?
Old Apr 30, 2007 | 05:49 PM
sohcvtec91hatch's Avatar
Default Quick 2.5" exhaust ?
Okay I'm going to be running a 2.5" dp on a T3 setup. Right now I have a 2.25" exhaust. I know I will have to go bigger or it will bottle neck which is a big no no. I also have to run some sort of muffler to keep the exhaust quiet under 2k rpm because of noise ordinace in the community I live in. I was thinking of going 2.5 from the DP back but maybe going with 3" after the axle or right after the S curve. My questions are what can I use to keep the noise quiet and also the exhaust exits on the passenger side for better flow so there isn't much room to work with. Please help me out!
This is how the exhaust is ran but with a stock style muffler not the can.
Old Apr 30, 2007 | 06:45 PM
vtec.dc2's Avatar
Default Re: Quick 2.5" exhaust ? (sohcvtec91hatch)
how much hp are you making? has it ever been on dyno?
Old May 1, 2007 | 04:20 AM
Default Re: Quick 2.5" exhaust ? (vtec.dc2)
No it has never been on a dyno. I don't have the turbo on yet i'm just getting all of the stuff together so I can do it all at once and do it the right way.
Old May 1, 2007 | 04:58 AM
miller's Avatar
If you are going to go turbo just put a 3" or bigger on there from the get go.
Old May 1, 2007 | 06:58 PM
Default Re: Quick 2.5" exhaust ? (miller)
But I have to keep the noise down. Is 3" that much louder than 2.5?
Old May 1, 2007 | 07:12 PM
RedEj8's Avatar
There is such thing as a quiet 3" exhaust...Use a resonator or 2, or if you want to use a cat, use a 3" hi flow cat and 1 resonator and muffler at the end. Check into some kind of muffler like a magnaflow or the apexi world sport turbo muffler.
Old May 1, 2007 | 07:13 PM
HondaCivicSiR1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">If you are going to go turbo just put a 3" or bigger on there from the get go. </TD></TR></TABLE>that is going in my sig and no you don't need a 3'' exhaust unless your planning on making over 300whp.what i'm going to do on my ef hatch is have a 2.5"down pipe with a 2.5"cat-back,so maybe if used a that with a 2.25 muffler that would keep the sound down some and shouldn't be to restrictive. but it never hurts to search around here and hmt.com to get some better answers good luck with it.
Old May 2, 2007 | 05:01 AM
Default Re: Quick 2.5" exhaust ? (HondaCivicSiR1)
If you put all of that 2.5" stuff and then ran a 2.25" muffler wouldn't it restrict flow like crazy at the end and cause all sorts of back pressure. And like I said it only has to be quiet under 2k rpms. I was looking at the Tanabe Medalion Concept G but they only make them in a system and I don't have that kind of money.
Old May 2, 2007 | 06:22 AM
HiProfile's Avatar
I would suggest getting a 180* bend and a straight-through resonator. Put the resonator in the stock horizonal muffler position, and let the fart can you have exit out the passenger side. You really don't see much restriction from the longer exhaust, esp if you instead switch to a baffled muffler to keep that shorter run.
Old May 2, 2007 | 08:41 AM
Default Re: Quick 2.5" exhaust ? (HiProfile)
I don't have the Can anymore, I have a stock style universal muffler. I may use a resonator but if I do it will be under the car in the tunnel.
Octanez
15
May 16, 2012 07:57 AM
boxeocampeon
May 16, 2010 04:28 PM
boostedb20ek
Nov 11, 2009 03:40 PM
Scotty Dosent Know
Aug 31, 2007 01:24 PM
xionl1350
Feb 23, 2007 03:34 PM
