question for you welders
when welding the oil return line, what temperature is the flame? reason I ask is 'cause I have a hand-held micro torch that can flame 1300C, 2500F. is that hot enough or no?
I don't think the micro-torch has enough ***** to braze anything, you'll need a good torch for brass. Tin soldering probably won't hold up for long, if at all. I think a radiator shop can take care of that, or a good auto body shop. There are fittings to use that doesn't require any welding or soldering. I think they are called "through-wall" couplers, like a flared or barbed fitting on one end and threaded on the other end with a locking nut......
TB123
Jan 15, 2012 11:20 PM
teg racer 877
Jun 28, 2006 08:09 PM
cornhusker
Aug 22, 2004 01:22 PM
