question on injectors
Old Feb 5, 2002 | 08:07 AM
rob1208lv's Avatar
Default question on injectors
hi i have a drag3 turbo kit i bought some rc310cc and installed them, and im running real rich. im only @6lbs. i also bought a boost controller, should i install that and up the boost???? will this help with the lean, or should i take the injectors out and put it all back in when i get the hondadata??? 94 ls integra turbo
Old Feb 5, 2002 | 08:10 AM
dbman96's Avatar
New User
Default Re: question on injectors (rob1208lv)
Upping the boost might "help" the rich situation a little too much... I think the best thing for you to do would be to get an adjustable fuel pressure regulator and reduce your fuel pressures. Out of curiosity, is your "rich" reading based on an Air/Fuel gauge or on a wideband O2 meter at a dyno?
Old Feb 5, 2002 | 08:22 AM
rob1208lv's Avatar
Default Re: question on injectors (dbman96)
thanks
Old Feb 5, 2002 | 08:44 AM
rob1208lv's Avatar
any other ideas
Old Feb 5, 2002 | 09:35 AM
AE86's Avatar
your probably running rich at idle but when on boost your not.
Old Feb 5, 2002 | 10:00 AM
rob1208lv's Avatar
Default Re: question on injectors (AE86)
thats exactly whats happing, and some times lots of liquid comes out the exhaust
Old Feb 5, 2002 | 10:05 AM
AE86's Avatar
well the reason for this is that your still using the stock ecu and that was not programmed for 310's. I guess you could get yourself a apex afc and elimate some fuel at idle BUT I would recommend you go for an aftermarket programmable ECU.
Old Feb 5, 2002 | 10:17 AM
rob1208lv's Avatar
like hondadata 2b or ????
Old Feb 5, 2002 | 10:24 AM
AE86's Avatar
well i don't care much for the hondata's. I would personally use a dfi, haltech, tec 2 or 3 if it's out, or AEM.
The aem would be my first choice though.
Old Feb 5, 2002 | 10:31 AM
93LSivic's Avatar
Did you remember to replace the 12:1 disc with an 8:1 in your FMU? Thats your problem!
Old Feb 5, 2002 | 10:46 AM
AE86's Avatar
Default Re: question on injectors (93LSivic)
DAM... 12:1 You don't need that much!!! 110psi !!! IF your running that much you should definitely change it.
dale187
Dec 8, 2008 10:04 AM
tunedek
Aug 22, 2006 08:39 PM
Pengo
Dec 27, 2002 03:28 PM
nosintegra92
Apr 10, 2002 02:39 AM
