Help bearing sizes/colour Eagle Rods b16
Hey all today I found out that Honda love to colour code things, and im very quickly trying to learn what bearings to use where, and which ones to get.
Now im replacing my main’s bearings ( all 10 of them ) with new ones and replacing them with the same colours I already have. (This is correct yeah !! ?? )
1=brown
2 = green
3 = brown
4 = green
5 = green
But for my new Eagle rods im trying to work out what colour’s to get.
Currently with the stock rods I have
1 = green
2 = brown
3 = green
4 = green
Now I know there’s a section in the helmes that talks about what combo with what.
Dustin was very nice some time ago and scanned the correct pages. https://honda-tech.com/zerothread?id=183507
Now to work out the rod bearing normally you read the number off the side of the rod, but eagle rods don’t have numbers…
Iv also done some searching and people seem to say to assume all eagle rods are classified as Size 3, but I also read that eagle rods for b16’s should be considered as size 3 ? can anyone confirm this ?
Also does anyone have eagle’s phone number (bc my box with my rods are at the work shop and I wanta call the USA to ask eagle directly also, if needed)
Regards James
1=brown
2 = green
3 = brown
4 = green
5 = green
1 = green
2 = brown
3 = green
4 = green
Regards James
Re: Help bearing sizes/colour Eagle Rods b16 (BLKCRX)
You can use the #3 size convention for the Eagle rods (as a starting point) but you should still plastigauge to check the oil clearance.
[Modified by SLPR, 6:56 AM 7/17/2002]
Re: Help bearing sizes/colour Eagle Rods b16 (SLPR)
actualy i did a webseach and found this..
http://www.plastigauge.com/
which answers a lot of questions...
lol next question what are the Clearance for b16 rods / crank ?
Regards James
Regards James
New User
Can I be honest...??
I suggest that if you are building a motor and do not know the clearences that you go out and buy a Helms right this second. All of this information is in the helms and it tells you the things to look out for... It would be WELL worth your money to buy one if you are building the engine... I would hate to see you build this engine and have it blow up in a week...
Re: Help bearing sizes/colour Eagle Rods b16 (GSR_Hacker)
Yeah i personaly don't know them but my mechanic doing all the work.. should / will
But thanks for your advice guys !
Regards James
Regards James
the.hamburglar
02-18-2007 10:43 AM
SpoonFed
01-04-2003 04:35 PM
