Question on coolant leak in engine...
Old Sep 27, 2001 | 11:03 AM
boost killz's Avatar
New User
Default Question on coolant leak in engine...
Has anyone on this board noticed if you follow top coolant hose coming from radiator to the engine, the assembly it connects to has a 90 degree pipe coming off that assembly connecting to a hose. I've seen a coupe other gsr's that have had the problem on that 90 degree bend that it leaks coolant from the connection on the assembly itself but not from the hose.... Have any of you seen this and was there any factory defect on that piece? And also would JB weld around that connection be good enough to sustain the engine heat and keep it sealed from leaking? Thanks guys,
Nick
[Modified by boost killz, 12:05 PM 9/27/2001]
Ayashifx55
Dec 23, 2010 10:01 PM
TooManyTickets
Apr 15, 2008 06:56 AM
creepy116
Aug 5, 2007 08:51 PM
tFUnK
Jan 2, 2003 12:56 AM
