Question about Tial wastegates - and springs
I'm running 35mm wastegate with 4.35psi spring..
1) Can .2bar spring from Tial 46mm wastegate fit Tial 35mm wastegate?
2) And.. can .25bar spring from Tial 38mm or 40mm wastegate fit 35mm?
Thanks
Thanks
HT's Biggest Loser
Re: Question about Tial wastegates - and springs (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">I'm running 35mm wastegate with 4.35psi spring..
Thanks
They are all interchangable.
Thanks
Actually on the 35mm gate you will need to use a small spring. They dont accept the larger springs. In turn, the 38, 40, 46mm(i think on the 46, not too sure) gates can use a small or large and even a combination of the 2.
