question about a T3
Old May 1, 2004 | 05:32 PM
Btothe3rdDegree's Avatar
Default question about a T3
can i rotate my whole bearing section of my turbo? the water ins and outs are on top and bottom instead of the oil in and outs, so can i rotate the bearing section, or should i rotate the compression and exhuast housing, if i have to rotate the two housings do i undo the bolts holding the two housing and turn them? clockwise? counter clockwise?
thanks guys
Old May 2, 2004 | 06:30 AM
Default Re: question about a T3 (Btothe3rdDegree)
anyone?
Old May 2, 2004 | 08:27 AM
TABIAS's Avatar
I want to be MADE into Ice-T
i was wondering the exact same thing, 3rdDegree, are you planning on useing the water cooling? i havn't decided yet weather or not if i am...
Old May 2, 2004 | 09:12 AM
Default Re: question about a T3 (preacherboy)
yes i am, easy connection and it will help the longevity of the turbo so water gets a from me
Old May 2, 2004 | 09:36 AM
b16ahybrid's Avatar
Yes you can rotate the bearing housing. Just loosen the bolts and rotate
Old May 2, 2004 | 10:09 AM
Default Re: question about a T3 (b16ahybrid)
well i am trying to rotate the exhuast housing only is that possible? i loosened the bolts on the exhuast housing and it won't budge, i would take the bolts off completely but the coolant holes are in the way am i doing it right?
Old May 2, 2004 | 11:44 AM
Slammd Sol's Avatar
The exhaust side can be a pain in the *** to get rotated. First losen all the bolts on the exhaust side and tap the exhaust side out/away from the middle. Then put the ex. side in a vice and use a really big plumbing wrench and rotate the middle section.
NZXTInerTia
Apr 16, 2013 10:06 PM
nico.tico
Nov 19, 2010 05:17 PM
boosted-delslow
Sep 21, 2004 08:09 AM
M.A.R.C.
Jul 16, 2002 07:33 PM
