Question about Studs (manifold to turbo)
Old Dec 1, 2004 | 01:22 PM
liquidxEG's Avatar
Default Question about Studs (manifold to turbo)
So, the way i did studs on my last homemade manifold, i just took a long bolt and cut the ends off of them. it worked.
This time, on my lovefab, I was going to do the same thing. The guy at the hardware store, however, said since the manifold and the tubo are so hot, unless the stud is specifically sized, and has an unthreaded portion in the correct location, the stud will back out. why exactly is this? I'd really rather not **** around and have my turbo drop out the botom of my car
Any advice? or should i just try to squeeze some bolts and split lockwashers on there?
Old Dec 1, 2004 | 01:34 PM
DRAGLS's Avatar
Default Re: Question about Studs (liquidxEG)
I do that all the time you will be fine!
Old Dec 1, 2004 | 03:03 PM
liquidxEG's Avatar
Default Re: Question about Studs (DRAGLS)
Perfect! I didn't quite understand how the unthreaded portion had anything to do at all with the stud, but whatever. thanks a lot!
Old Dec 1, 2004 | 04:34 PM
IvanB's Avatar
I used the studs that came with the turbo and 2 of 4 bolts fell out after about 200 miles. I didnt notice it until too late since it was the bolts hidden out of my view from the top.
I think your screwed if you dont use lock washers and loctite. even loctite is only rated to like 600 degrees tho.
good luck.
Charlie Moua
Nov 22, 2010 04:44 PM
leroy12
Feb 12, 2010 12:41 PM
DubyaAye
Feb 10, 2004 03:34 PM
FredoSP
Jan 19, 2004 07:09 PM
BoOsTeD_eK
Jul 9, 2002 06:11 PM
