Question about running rich...
Old Apr 16, 2005 | 04:55 PM
Jayboy's Avatar
Default Question about running rich...
So I've got a completely built block (9.1 forged pistons, eagle rods, arp bolts etc.) and a mild port job on the head with mildly port IM. I'm running a 255 walbro intank, 310's and the greddy blue box, FP is set at 36psi with hose on. (7psi of boost) I think that my motor is running very rich, cause on the freeway whenever i give it about half throttle anything under 4000rpm (especially in 5th) the motor bogs pretty bad. I have the autometer guage(i know they suck) but it shoots to all the way green whenever it bogs. Uberdata is on the way. The question is should I turn down the Fuel pressure to say 33-34 would that alleviate some of the bogging? keep in mind i dont want to run lean while boosting above 4000. will the blue box compensate enough?
Old Apr 16, 2005 | 11:57 PM
Wideopentuning's Avatar
Default Re: Question about running rich... (HollywoodEG6)
Green just means richer than 14.7:1. Useless.
Old Apr 17, 2005 | 06:44 AM
Muckman's Avatar
Moderator in Chief
Why did you create two threads about the same topic, the same day in the same forum? https://honda-tech.com/zerothread?id=1215422
Jayboy
Apr 29, 2005 03:40 PM
MachAF
May 29, 2004 08:08 PM
E-spec Tuner
Mar 20, 2004 04:59 PM
spooned out
Aug 7, 2003 09:49 AM
00 Si
Nov 1, 2001 09:10 PM
