question about leakdown results
Old 11-26-2008, 11:58 AM
blackeg's Avatar
Default question about leakdown results
ok did the old leakdown test. came out between 10-20% for all cyls. compression is 198-205psi and the motor is 9:1 static compression.
when doing the leakdown i could hear the air coming out of my catchcan with the oil fill cap on, and it came out the oil fill cap hole with it off. ive always done leakdowns with the cap off so ive never heard it from the catchcan before. what would air leaking out of those spots indicate? bad rings? it came out of these places with every cylinder. thanks
Old 11-26-2008, 12:27 PM
90sedan's Avatar
If you can hear the air coming out of the crankcase, then the rings are the source of the leakage.
Did you get the motor up to operating temp before doing the leakdown? If not, try it again with the motor warmed-up.
Old 11-26-2008, 12:41 PM
ABK
ABK's Avatar
Yea did you warm up the engine? Built boosted motors run loose clearances so up until it warms up it will have some blow by.
Old 11-26-2008, 12:42 PM
95jeremie's Avatar
wouldn't that be the valves? in the catch can and oil fill cap...
that would be the top end
given the catch can woul leak from the bottom end as well depending on how it is set up...
but i'm dislexic so... i could be wrong on this one...
Old 11-26-2008, 12:46 PM
90sedan's Avatar
No, you would not hear the valves leaking into the crankcase because they can't.
If the intake valves were leaking you would hear it out of the intake manifold.
If the exhaust valves were leaking you would hear it out of the exhaust manifold.
Old 11-26-2008, 12:49 PM
95jeremie's Avatar
cool thanks for clearing that up
Old 11-26-2008, 05:28 PM
blackeg's Avatar
motor was warm, coolant was around 170 and oil temp was about 160.
ring gaps are a tad big, .022 top ring and .025 second ring. its a benson sleeved 84mm with cp pistons. bottom end has about 9k miles of 400+ hp, headgasket was changed once.
Old 11-27-2008, 04:00 AM
turbo-crx's Avatar
Isn't .022 a little tight and cause blow-by?
Old 11-27-2008, 05:08 AM
i ♥ snails
quicksilver1689's Avatar
yeah 20% seems a tad on the high side but if its not getting worse rock it.
Old 11-27-2008, 05:51 AM
blackeg's Avatar
the compression hasnt gone down at all. leakdown was about 10% when the motor had 1000 miles on it, so it got a lil worse. im not planning on going to the track or anything with it anymore, just wanted to really see what the air in the catchcan has to deal with.
dE.fUsEd
04-03-2012 08:58 AM
Old goat
11-19-2010 06:54 PM
Mikey3000
12-12-2007 04:08 AM
crx1856
11-16-2003 12:03 PM
Infinity_Racer
11-06-2003 07:23 PM
Quick Reply: question about leakdown results
