Question about CP pistons...
Old Jul 28, 2005 | 06:05 PM
*Boostwerks*'s Avatar
Default Question about CP pistons...
Do the honda applications come with an offset wrist pin?
Simple question, that I couldn't find on their website.
Thanks,
Bryson
Old Jul 29, 2005 | 11:57 AM
bump
Old Jul 29, 2005 | 01:35 PM
earl's Avatar
Default Re: (Bryson)
I think Wisecos are offset but not CP or JE. CP does not believe off setting is of any benefit to a performance piston.
Old Jul 29, 2005 | 01:38 PM
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">I think Wisecos are offset but not CP or JE. CP does not believe off setting is of any benefit to a performance piston.</TD></TR></TABLE>
Yeah, I knew wisecos were, but I was just wondering if CPs were since they stock an off the shelf 84.5mm piston, but wiseco does not.
I think the offset wrist pin helps engine longevity by keeping the pistons from rocking in the bore. If you think about it, all of the stock Honda pistons have an offset wrist pin.
Old Jul 29, 2005 | 07:50 PM
earl's Avatar
Rocking is a problem with oem honda pistons but not aftermarkets. Wiseco just copied the oem design. I have never seen any evidence in my own race motors of rocking pistons and CP says it won't happen. There is a reason that all the major players do not use offset pins. It would not cost anymore to build them with an offset if that was important.
Old Jul 30, 2005 | 11:42 AM
Hrmm...interesting. Why would rocking be a problem with oem but not aftermarket?
Old Jul 31, 2005 | 11:28 AM
earl's Avatar
cast aluminum strength compare to forged aluminum, I believe, along with clearances used.
Old Aug 6, 2005 | 07:28 AM
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">cast aluminum strength compare to forged aluminum, I believe, along with clearances used.</TD></TR></TABLE>
Hrmm...I thought it would have had more of an issue with cylinder wall wear, than strength?
PhatBoy5015
Aug 7, 2006 08:52 AM
h22_crx
May 4, 2006 04:57 AM
dude_123
Sep 29, 2005 08:02 AM
MackDad
Sep 14, 2005 05:36 PM
rusted_eyes
17
Jul 13, 2004 05:28 PM
