Question about ARP headstuds did search
Old Oct 11, 2003 | 05:27 AM
GreddySi99's Avatar
Default Question about ARP headstuds did search
ON the instructions in the box it says when using ARP moly lube to torque to 75 Ft lb. when using motor oil torque to 95 Ft lb. then on the very bottom it says something about aluminum and to torque aluminum to 45 Ft lb. This is for headstuds of course. so what is the torque really supposed to be?????? 75???? thank you all
Old Oct 11, 2003 | 05:40 AM
CRVRX's Avatar
Default Re: Question about ARP headstuds did search (intercooledJRSC)
I have always installed the studs in by hand untill they stop. Then using the moly lube, torque them to factory specs. I have used these studs on the last 40+ motors I have built, Never seen a problem with them.
The ones in my car have been re-used 7 times (Trying new heads) and they are fine too.
Btw. Thanks for the SC manifold John.
Old Oct 11, 2003 | 09:07 AM
GreddySi99's Avatar
Default Re: Question about ARP headstuds did search (CRVRX)
anyone else have input???? not that I dont trust you john I just want to hear more testimonies
Old Oct 11, 2003 | 09:11 AM
Boostfed's Avatar
New User
65ft-lbs with ARP moly lube and 81 ft-lbs oil. That is for an aluminum head. But I don't remember my torque specs for my old ARP being 75ft-lbs non aluminum but though they were 70ft-lbs.
Old Oct 11, 2003 | 09:50 AM
89dxhunchback's Avatar
Default Re: Question about ARP headstuds did search (Boostfed)
Don't forget to "torque cycle" the studs/nuts.
If you plan on never taking the studs out you can use loc-tight on the block threads.
truteg801
Jan 3, 2007 08:31 PM
djtony5
Nov 17, 2005 02:48 PM
one pnt 6 hatch
Apr 25, 2005 08:48 PM
