Question????
Old Oct 26, 2012 | 02:44 PM
gpr's Avatar
gpr
Default Question????
What piston/rod combination works for a 650hp build?
Old Oct 26, 2012 | 03:01 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Question????
Can you be MORE vague?
Old Oct 29, 2012 | 08:24 AM
gpr's Avatar
gpr
Reason i ask is because as soon as you mention anything over 500hp all you hear is manley I beam (turbo tuff) or pauter. Now why would i use a 1000hp rod if i can find something in the 650 range, and yes i've use the search button so your comment are not needed.
Old Oct 29, 2012 | 08:36 AM
Turbo-LS's Avatar
you would be pushing the limit on any economy H beam rods but they've worked in the past. Reason people mention higher end rods is because instead of running on the ragged edge of the tinsile strength of a rod its better to be in a lower range of that strength.
Old Oct 29, 2012 | 03:14 PM
The Grumpiest
And yet you ask anyway. In all your "reaserch" have you found any combo that meets your criteria? Sounds like you're being motivated by limited budget instead of common sense. I say "sounds like" because you still haven't come off of any info to help you make a valid and sound decision.
Old Oct 29, 2012 | 03:34 PM
SiRCiviC94's Avatar
push the eagles and wiseco's to the max.
Old Oct 29, 2012 | 05:04 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Sure, he has a build duh!
D, B, F, H, K, J, ect series? Haha, what does that matter? It isn't like there are a million combinations available. Only a few dozen IF he is even talking Honda's.
So to answer your question OP - Use stock rods for those power levels on your (fill in the blank) build. You will be happy you did!
Old Oct 29, 2012 | 06:26 PM
gpr's Avatar
gpr
GSR, thanks for the advice very helpfull.
95civhb
11
Feb 20, 2009 04:08 AM
Jdmglenn
Jul 23, 2005 06:55 PM
94CivSi
14
Apr 15, 2004 04:34 PM
94CivSi
Apr 11, 2004 06:14 PM
shiftgear8000
Mar 19, 2004 10:09 PM
