quad stage boost controller
Old Apr 6, 2006 | 11:56 PM
morgan@synapse motorsport's Avatar
Default quad stage boost controller
just wanted to verify before i make anymore progress. im running a dual wastegate setup i have 2x 9psi springs in each wastegate. i want to run 9psi in first 14-15 in second, 18-20 in third. and 30+ in fourth. will the turbo xs quad stage boost controller allow you to more than double the wastegate spring? so will i be able to run 9psi and 30+psi on the same springs? or would i be limited to double the springs at 18psi?
if it wont do it are there any boost controllers that can do this for me?
Old Apr 7, 2006 | 04:47 PM
DaveF's Avatar
Default Re: quad stage boost controller (hybrdthry911)
NLR with c02
Old Apr 7, 2006 | 08:25 PM
littlebluecrx's Avatar
you should be able to go over 30 psi with your setup, I know I have in 5 different cars 1 of them with 2 wastegates, with 9 psi springs...
Old Apr 8, 2006 | 08:45 PM
PTR1's Avatar
i was wondering when you run the vaccumn lines. is it the same for internal and external wastegate?
Old Apr 9, 2006 | 02:19 AM
yes it is the same
Garage 808 Hatch
Dec 31, 2006 06:17 PM
building boost
Dec 7, 2006 12:51 PM
AZNracerx1989
Jul 18, 2005 10:12 AM
Racer X
Mar 27, 2003 01:07 PM
