PWR Liquid/Air Specifications
Old Aug 8, 2006 | 04:24 AM
SPOOLINmatt's Avatar
Default PWR Liquid/Air Specifications
how much power would it be safe to assume based on real results that the PWR Liquid to Air 6x8 barrel style intercooler can support. their site says 600whp. and it flows 920cfm.
i cant remember the formula to calculate cfm into ppm
Old Aug 8, 2006 | 06:25 AM
josh green's Avatar
Default Re: PWR Liquid/Air Specifications (SPOOLINmatt)
bump
Old Aug 8, 2006 | 12:42 PM
ttt
Old Aug 8, 2006 | 01:06 PM
gldndrgn14's Avatar
try calling them. i am sure they can help you.
Old Aug 8, 2006 | 01:10 PM
Default Re: PWR Liquid/Air Specifications (gldndrgn14)
im looking for real life experience, not a manufacturers blah blah.
Old Aug 9, 2006 | 12:20 PM
gldndrgn14's Avatar
ah, i see. well im going to run 1 soon. hopefully its as good as they say. or if you really want a good water to air ic, get a spearco 2-230 or 2-231. those are tried and proven. 2-231 would be good for your goal.
Old Aug 9, 2006 | 12:26 PM
pwr said they had a customer make 750 on this model.
Old Aug 9, 2006 | 03:14 PM
earl's Avatar
We made in the 800's with the 6x10
I don't see why the 6x8 cannot do similar but it would not have quite the same cooling capacity.
Old Aug 9, 2006 | 03:17 PM
Justin Olson's Avatar
Default Re: PWR Liquid/Air Specifications (earl)
What kind of pressure drop and temperature differential were you seeing across the core?
Regards,
Justin
Old Aug 9, 2006 | 03:37 PM
gldndrgn14's Avatar
Default Re: PWR Liquid/Air Specifications (Justin Olson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Olson &raquo;</TD></TR><TR><TD CLASS="quote">What kind of pressure drop and temperature differential were you seeing across the core?
Regards,
Justin</TD></TR></TABLE>
Old Aug 9, 2006 | 08:44 PM
that sounds awesome earl.
i guess ill see what happens.
Old Aug 9, 2006 | 10:12 PM
earl's Avatar
Regards,
Justin</TD></TR></TABLE>This was a couple of years ago but I remember the pressure drop was only 2-3 pounds and intake temps something like 80 degrees F. This was using a 3 gallon ice/water tank, however.
Old Aug 10, 2006 | 07:48 AM
Very impressive. I'd assume the garrett cores are as capable or more so they these bullett intercoolers. I just dont see too many of these PWR cores on drag cars.
Regards,
Justin
Old Aug 10, 2006 | 04:33 PM
gldndrgn14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Olson &raquo;</TD></TR><TR><TD CLASS="quote">Very impressive. I'd assume the garrett cores are as capable or more so they these bullett intercoolers. I just dont see too many of these PWR cores on drag cars.
Regards,
i just dont see them on many cars period. haha
integra3586
Apr 9, 2006 07:34 PM
jkeno112
Sep 18, 2005 10:16 AM
NLR808
Aug 5, 2004 04:49 AM
94TealGSR
May 11, 2003 10:01 PM
johnisenglish
Apr 22, 2003 06:35 PM
