Pump ok to install by itself?
Old Jan 29, 2005 | 08:29 AM
VspecSiR's Avatar
Default Pump ok to install by itself?
Will i have idle problems by installing a walbro fuel pump (199lph) by itself w/out an adjustable FPR?? I have 310cc injectors by the way.
Old Jan 29, 2005 | 08:41 AM
primeredbeast's Avatar
Default Re: Pump ok to install by itself? (VspecSiR)
nope my buddy had this setup on his civic
Old Jan 29, 2005 | 09:08 AM
DefiantGSR's Avatar
Default Re: Pump ok to install by itself? (primeredbeast)
you'll be fine but it may raise fuel pressure. there have been quite a few instances where it would raise FP ~10psi..
Old Jan 29, 2005 | 09:17 AM
boosted92's Avatar
Default Re: Pump ok to install by itself? (DefiantGSR)
I'd skip it for now, you'll just be running rich untill you get the FPR on there.
Old Jan 29, 2005 | 01:16 PM
VspecSiR's Avatar
Default Re: Pump ok to install by itself? (boosted92)
well better rich then lean, i should also probably point out that this is a greddy turbo kit w/the blue box. People tell me the blue box make the car run rich, well my car is not running as rich as people say, in fact i checked my plugs the other day, and the look a little lean.
Old Jan 29, 2005 | 01:55 PM
DefiantGSR's Avatar
A fuel pump won't do jack. Get larger injectors.
Mike Lowwryyy
Jan 25, 2012 08:37 AM
E-spec Tuner
May 7, 2003 02:05 AM
clean
Apr 15, 2002 04:45 AM
LS-T
Dec 16, 2001 12:01 AM
