which fuel pump...recommendation
Old Dec 14, 2001 | 04:24 PM
LS-T's Avatar
New User
Default which fuel pump...recommendation
I heard many ppl saying to upgrade the fuel pump from the DRAg kit because it isn't good or safe..i don't remember.
What do u guys think about Bosch fuel pump?? One guy said its average
i am new to this and don't have much clue which one is safer and better.
i will be running 6-8psi daily driven...please help me decided on a pump.
while at it...how about injectors....310??? necessary? will if affect performance with the setup that i'll be running...
thanks
Old Dec 14, 2001 | 06:05 PM
IMPATIENT's Avatar
Default Re: which fuel pump...recommendation (Armani692)
i am running the bosch pump and i haven't had any problems, i run 8 psi daily and its seems to be fine, 310 injectors would be tight but i believe you will need an afc to make it work properly
Old Dec 14, 2001 | 06:28 PM
GruvyTune's Avatar
New User
Default Re: which fuel pump...recommendation (IMPATIENT)
Walbro 255HP
Old Dec 14, 2001 | 10:53 PM
Markaccord95's Avatar
Default Re: which fuel pump...recommendation (GruvyTune)
you mean 255lph
Old Dec 14, 2001 | 11:58 PM
TurboITR's Avatar
Default Re: which fuel pump...recommendation (Markaccord95)
get a bosch
Old Dec 15, 2001 | 12:02 AM
integRated109's Avatar
i bought a holley 255lph from summit, pretty chep and no problems yet.
Old Dec 15, 2001 | 12:23 AM
Arturbo's Avatar
Better than steak
25 Year Member
Walbro 255HP
But remember he is running a Fmax turbo kit that has the addional injectors and MF2. He is not running the FMU like all of use with the drag or rev-hard. DO NOT RUN A 12:1 FMU WITH THE WALBRO!!
Even if you have elementry math you should be able to figure out that it will not work. Walbro themself tell you it wont work. Look on the freakin box.
art
Old Dec 15, 2001 | 03:51 AM
GruvyTune's Avatar
New User
Default Re: which fuel pump...recommendation (Arturbo)
I have the fmax with no fmu but the hondata with RC440s.
I have the high pressure version of the Walbro pump that has a higher duty cycle and can sustain the higher pressures if needed.
Old Dec 15, 2001 | 04:45 AM
TurboSedan's Avatar
New User
With the Drag kit, get the Bosch pump. It can run very high pressures fine. If you ditched the 12:1 FMU the Bosch would then not be necessary, the Walbro 255lph would be fine.
Old Dec 15, 2001 | 06:05 AM
b18cTurbo's Avatar
Default Re: which fuel pump...recommendation (97CivicFerio)
i have the holley 190 lt its cheap and good for 600 hp say holley!!!!
i dont get it y all fi people get the 255 lt
the 255 is good to 800 hp lol and it cost almost twice then the 190 lt
or corect me
Old Dec 15, 2001 | 07:15 AM
TurboSedan's Avatar
New User
Default Re: which fuel pump...recommendation (mikvtec)
Nah, depending on where you buy from the 190lph is not mush less than the 255lph.
Old Dec 15, 2001 | 07:47 AM
1's Avatar
43 GPH.... got mine mounted near tank and can barely hear it.
Old Dec 15, 2001 | 07:55 AM
Tomakit's Avatar
or corect me
600 hp yeah, but it wont do 10 hp at 120psi fuel pressure.
It just can't flow enough fuel at higher fuel pressures.
Tom
TurboSedan's Avatar
New User
Default Re: which fuel pump...recommendation (1)
I have an intake 255lph and I can hear that beitch at idle, especially right when I start the car. After a I drive for a bit then idle it does not seem to sound as loud, but it may just be me!!!
Old Dec 15, 2001 | 08:37 AM
turbogsr's Avatar
AEROMOTIVE!!!!!!!
Old Dec 15, 2001 | 08:56 AM
bottlefedb18c1's Avatar
i am running a fmu 12:1 with a walbro 255 lph and i have a drag kit and it doesnt give me any problems it seems to me that it runns better then with the one that came with it and it was like $$125 from summit the holley pump and the BBK pump is the same dam pump but the BBK is cheaper and thats what i have in my 1995 gsr and i love it
Old Dec 15, 2001 | 09:28 AM
jinxproof99's Avatar
New User
Default Re: which fuel pump...recommendation (turbogsrb18c1)
i've got the bbk too.
Old Dec 15, 2001 | 09:34 AM
b18cTurbo's Avatar
Default Re: which fuel pump...recommendation (jinxproof99)
It just can't flow enough fuel at higher fuel pressures..
i dont think that injector likes 120 psi
Old Dec 15, 2001 | 09:59 AM
ForcedAccord's Avatar
Texas B*tch!
Nothing wrong w/ the walbro.
Old Dec 15, 2001 | 10:02 AM
TurboInteg95's Avatar
This is great, so much misinformation.
Old Dec 15, 2001 | 10:20 AM
1's Avatar
Default Re: which fuel pump...recommendation (TurboInteg95)
Oh boy, here comes Mr. Expert with no info to back up his statements re: fuel pumps. Just trust me!
Old Dec 15, 2001 | 10:53 AM
bigTom's Avatar
its funny how ANYONE makeing any sort of decent power doesnt use an in-tank... 600hp on an intank ur telling me?i cant say if it possible or not... but i sure as hell wouldnt trust it
Old Dec 15, 2001 | 11:12 AM
New User
Default Re: which fuel pump...recommendation (Tom)
i would say anything over 350 to the wheels would begin to require something more than an in tank. not saying more hsp isn't possible, its just pushing it. but to each his own around here i guess.......
Old Dec 15, 2001 | 12:26 PM
turbopanda's Avatar
i have my stock in-tank fuel pump leading to another small 500ml aluminium fuel tank which then leads to my bosch pump (outside the tank, mounted underneath the car - dangerous, I know ) then to the engine. I boost heavy, and the fuel pump feeds 8 fuel injectors on my car (4 x D16Y8 injectors and 4 x B18C injectors) - I'm using the stock fuel pressure regulator that came with my engine, and I haven't had any problems whatsoever. Bosch pumps are cheap too. If it does the job, its good enough for me. Don't buy something that is over-spec, you're just wasting your money. My fuel pump is the ones that they use in the S500 Mercedes Benz. Can get a *little* bit noisy if i'm running low on gas (ie. when the low-fuel warning light is on).
[Modified by nathan's boosted civic, 4:28 AM 12/16/2001]
Old Dec 15, 2001 | 01:32 PM
Arturbo's Avatar
Better than steak
25 Year Member
Yup.....
