Pros and Cons of test pipe?
Old Feb 8, 2003 | 02:05 PM
greddyturboGSR's Avatar
Default Pros and Cons of test pipe?
Ive been hearing things both good and bad about running a test pipe. Is it worth the hp gains? Where is the best place to get one made? Also, I live in Cali so what kind of fines am I looking at if I get caught without a cat? pics welcome
thanx
Old Feb 8, 2003 | 02:23 PM
Default Re: Pros and Cons of test pipe? (greddyturboGSR)
anyone have experience with a bad odor due to the lack of a cat. converter?
Old Feb 8, 2003 | 03:36 PM
anyone??
Old Feb 8, 2003 | 03:38 PM
blufke's Avatar
you will smell it.
Old Feb 8, 2003 | 03:40 PM
AB16A2T's Avatar
Pros: Small Power Gains over Cat, unless you are running high boost and then it's even larger gains
Cons: Smells
Big fat TICKET depending on where you live, IE Cali = $5000 ticket I believe.
Polluting the environment.
Old Feb 8, 2003 | 03:45 PM
Evil EG's Avatar
Default Re: Pros and Cons of test pipe? (AresB16A2Turbo)
Pro - More Power
Cons - OBD2 = Check engine light, fail smog tests
thanx guys, I think I will deal with the loss in hp to avoid the fines and odor. Atleast I could always tell my girl it wasn't me stinkin!
Old Feb 8, 2003 | 03:47 PM
If the check light and failing smog were the only cons then I would go for it. Im interested in how bad the fine would be.
Old Feb 8, 2003 | 03:50 PM
blkDOHCsol's Avatar
New User
when you hug your girlfriend when you get to her house..she will tell you that you smell like gas...
Old Feb 8, 2003 | 03:51 PM
zip's Avatar
zip
Testpipe
tuning
= no smell, no CEL, and a lot of
Old Feb 8, 2003 | 03:58 PM
JDMs1eeper's Avatar
Test Pipe helps a lot. it dont smell on my car either... get one that bolts up so you can put you stock cat on when you get your smog test (i live in VA w/o smog tests )
Old Feb 8, 2003 | 03:59 PM
98AccordEX's Avatar
Default Re: Pros and Cons of test pipe? (zip)
zip - do you sell the o2 simulators? or is that just a link to someone elses site?
Old Feb 8, 2003 | 04:03 PM
Default Re: Pros and Cons of test pipe? (98AccordEX)
but does anyone knwo what the fines are like?? I was thinking It would be more along the lines of a fix-a-ticket. But ive been hearing 4 digit numbers here!
Old Feb 8, 2003 | 05:07 PM
boostedsol's Avatar
I just got a testpipe. Reason being is that I would still fail emissions, so why not get a little bit more power out of it all? That's what I did, but it will still smell like gas regardless if you have a cat or a test pipe.
I dont know how strict the laws are where you are at, but in TX all you have to do is take it to a shop and pay them off w/ some $$ for your emissions sticker.
Hondachef
Jul 7, 2013 04:00 PM
accordjuggalo1796
Dec 12, 2009 10:43 AM
94integragsr
Jul 1, 2005 04:09 PM
caslmenow
Sep 11, 2002 04:51 PM
Mr. Vapor
Oct 17, 2001 08:35 AM
