Do i need a catch can?
Old Aug 3, 2009 | 07:39 PM
manuel12's Avatar
Default Do i need a catch can?
I recently just installed a turbo on my car. I made 300 hp and 220 tq on the dyno. Now i have oil in the spark plugs. I changed the valve cover gasket and seals. Still have some oil coming through. Someone said i might need a catch can for the higher oil pressure? Could this solve the problem? Thanks in advance
Old Aug 3, 2009 | 07:45 PM
accord_raffi's Avatar
Default Re: Do i need a catch can?
what car is it? my accord has "lower spark plug seals" that require you to take the rocker assembly out to get at.
Old Aug 3, 2009 | 07:50 PM
manuel12's Avatar
It is a 96 acura integra ls
Old Aug 3, 2009 | 08:13 PM
i'll have to try to look it up, but just so you know, your engine's oil system doesn't get more pressurized when you make more power. Your oil psi is still the same as it was when your car was stock.
Old Aug 3, 2009 | 08:30 PM
garyherr's Avatar
yes you do.I was recently in the same boat like.320hp and oilpan rear main seals valve cover seals leak on by one after replacing another.vent through the back of the block or valvle cover either way.symptom on mine were worse had oil in the chamber blew smokes from exhaust.After catchcan everything went away.
Old Aug 4, 2009 | 02:18 AM
omiehomie's Avatar
how big was the catch can that you installed on to your setup...? and all symptoms went away?
Old Aug 4, 2009 | 04:35 PM
manuel12's Avatar
Thanks. Anybody else have any opinions in this.
Old Aug 4, 2009 | 04:47 PM
1992Si's Avatar
Install a catch can.
Old Aug 4, 2009 | 04:50 PM
manuel12's Avatar
Is there kits out there or do I hav to get one fabricated?
Old Aug 4, 2009 | 06:09 PM
NLR808's Avatar
B&R fittings check them out T1 makes one also do a search their are a few threads people who made their own
Old Aug 10, 2009 | 02:34 PM
1992db2's Avatar
catch can....get one bro
Old Aug 10, 2009 | 03:52 PM
boostedcivicsir's Avatar
Mr. Badwrench
honda's barely can breathe stock.
a catch can is always a good idea.
LoveBrisk
Honda CR-V & Element
Jun 30, 2014 06:31 AM
keilux
53
Aug 17, 2009 05:43 PM
crizniz510
Mar 11, 2008 03:48 PM
XplodeTeg
Sep 30, 2007 06:57 PM
shingles
Dec 22, 2001 07:28 AM
