Propane injection?
Old Dec 14, 2003 | 09:14 PM
  #51
-=TWITCH=-'s Avatar
Default Re: (zomart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zomart &raquo;</TD></TR><TR><TD CLASS="quote">uh.. i'm not sure, but is propane flammable? what happens if you get in an accident with this stuff in the trunk? it seems like it would be flammable since it burns in your engine...</TD></TR></TABLE>
Yes it is! The tank is a lot stronger than your Gasoline tank and Gasoline is also flammable, LPG tanks a really overbuilt
Old Dec 15, 2003 | 08:32 AM
  #52
SuicideSlide's Avatar
Default Re: (-=TWITCH=-)
So how would running a system like this effect tunning. For example if you were running a hondata setup. Tune for low boost and 91 octane? Then tune for highboost with propane and 91 octane?
Old Dec 15, 2003 | 08:57 PM
  #53
turbogeekDA6's Avatar
Default Re: Anyone runnuing PROPANE INJECTION? (boosted92)
boosted 92- your buddy has a 250 shot on pump gas made possible through the octane increases provided by the propane, correct? could u shed some light on how to calculate the correct nitrous/propane ratios? i have been wanting to try this for quite some time. do u know anyone else that runs nitrous with propane that could provide tech info on their setup as well?
Old Dec 15, 2003 | 10:26 PM
  #54
-=TWITCH=-'s Avatar
Default Re: Anyone runnuing PROPANE INJECTION? (turbogeekDA6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogeekDA6 &raquo;</TD></TR><TR><TD CLASS="quote">boosted 92- your buddy has a 250 shot on pump gas made possible through the octane increases provided by the propane, correct? could u shed some light on how to calculate the correct nitrous/propane ratios? i have been wanting to try this for quite some time. do u know anyone else that runs nitrous with propane that could provide tech info on their setup as well?</TD></TR></TABLE>
There is really no Propane to Nitrous ratio, you just have to start out with to much propane and tune it down from there. Its all about datalogging!
Chris
Old Dec 15, 2003 | 10:52 PM
  #55
Hoosier Daddy's Avatar
Default Re: Anyone runnuing PROPANE INJECTION? (-=TWITCH=-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -=TWITCH=- &raquo;</TD></TR><TR><TD CLASS="quote">The kit I have is sold by http://www.importpowernline.com you can find the system here!
http://www.importpoweronline.c....html
i have pics and information about the kit in the forums also!
Chris</TD></TR></TABLE>
I remember when he first introduced it a few years ago.
Old Dec 16, 2003 | 11:47 AM
  #56
how do u know when to stop leaning out the propane mixture? is it similar to tuning with fuel jets? do the plugs look any different? is there any method that you would recommend to do this easy/safe?
Old Dec 16, 2003 | 02:27 PM
  #57
-=TWITCH=-'s Avatar
The way I would do it is take it to the Dyno. Or if you have a nice datalogger that can show EGT, A/F, knock sum, timing advance etc. Just use your datalogger to moniter all of the above and tune from there. Really not that hard. If you do not have a Datalogger take it to a Dyno and tune it there!
Chris
Old Dec 17, 2003 | 11:09 AM
  #58
-=TWITCH=-'s Avatar
ttt
Old Dec 18, 2003 | 08:50 PM
  #59
-=TWITCH=-'s Avatar
ttt
Old Dec 22, 2003 | 09:52 AM
  #60
-=TWITCH=-'s Avatar
ttt
Old Dec 22, 2003 | 03:21 PM
  #61
cornhusker's Avatar
this is very interesting. i am actually planning out a nitrous d16y8 crx and now i am considering propane injection. i've got a couple questions, like can the zex air amplifer be used to inject propane? also, how would the propane be actiavted with a nitrous kit like zex?
thanks
Old Dec 23, 2003 | 05:18 AM
  #62
-=TWITCH=-'s Avatar
Default Re: Anyone runnuing PROPANE INJECTION? (cornhusker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cornhusker &raquo;</TD></TR><TR><TD CLASS="quote">this is very interesting. i am actually planning out a nitrous d16y8 crx and now i am considering propane injection. i've got a couple questions, like can the zex air amplifer be used to inject propane? also, how would the propane be actiavted with a nitrous kit like zex?
thanks
The only thing that might hold you back with the ZEX Amplifier is the pressure that propane is injected. Nitrous is not regulated in most cases when its injected, So you are looking at a 1000+psi when nitrous is injected. Propane is injected at abou 90-100psi so the amplifier would not really help you. You can use any simple switch to activate the propane. You can tap off the TPS sensor wire that the ZEX kits uses. you can use a basic window switch that will activate the nitrous at any given RMP point.
Chris
Old Dec 23, 2003 | 05:45 AM
  #63
DA-MAX's Avatar
I read through the thread and maybe I missed it, but are there any detrimental(sp?) effects involved with propane injection??
Old Dec 23, 2003 | 10:02 AM
  #64
for those of you that have tuned on the dyno with propane... did you see power gains outside of what u expected to get from the increased boost/ timing? did anyone ever see low egts, high timing, high boost, and record a power loss? the reason i ask is because ive been debating the same thing on g2ic. some think that the propane will make the mixture so rich that the engine actually loses power. i think the trick to this is just getting the prop injection on point, but u guys that have done it let me know what you think. thanks again.
Old Dec 24, 2003 | 12:45 AM
  #65
cornhusker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">We ran propane on a buddies C5, replaced the wet side of a nitrous kit with propane and hes running a 250 shot on pump gas Works great, I love it.</TD></TR></TABLE>
how did you guys connect the propane tank to the nozzle/jet?
Old Dec 24, 2003 | 06:57 AM
  #66
ladysman's Avatar
I was ready to order this until I saw this.
For safety purposes use a CLOSED LOOP BOV ONLY to keep unspent Propane from entering engine compartment.
Most of use have open loop BOV's so this really isn't a good idea having a highly flammable gas in the engine bay.
Old Dec 24, 2003 | 07:03 AM
  #67
DA-MAX's Avatar
Default Re: Anyone runnuing PROPANE INJECTION? (ladysman)
WOW...thats a good heads up!!! didn't think of that.
Old Dec 24, 2003 | 08:42 AM
  #68
Default Re: Anyone runnuing PROPANE INJECTION? (DA-MAX)
could it seriously matter that much? if you were boosting and injecting propane, then you would hopefully be moving pretty fast. a lot of air would be moving thru the engine bay and under the car. it seems like the propane would disperse throughout surrounding atmosphere quickly and be extremely difficult to ignite unless one was trying to. what could possibly go wrong? in theory, it sounds dangerous, but can anyone substantiate this with any factual evidence?
Old Dec 24, 2003 | 10:43 AM
  #69
Cole D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogeekDA6 &raquo;</TD></TR><TR><TD CLASS="quote">could it seriously matter that much? if you were boosting and injecting propane, then you would hopefully be moving pretty fast. a lot of air would be moving thru the engine bay and under the car. it seems like the propane would disperse throughout surrounding atmosphere quickly and be extremely difficult to ignite unless one was trying to. what could possibly go wrong? in theory, it sounds dangerous, but can anyone substantiate this with any factual evidence?</TD></TR></TABLE>
point made but propane is too dangerous to take that chance I rather be safe than sorry propane is more volatile and flammable than gas I wouldn't do it on a open bov its not worth it I value my car more than 20hp
Old Dec 24, 2003 | 11:23 AM
  #70
2SLO's Avatar
this is awesome. lets see some pics of setups!
Old Dec 25, 2003 | 01:35 PM
  #71
-=TWITCH=-'s Avatar
Default Re: (2SLO)
If you want to see some pics of setups check out my site!
Chris
Old Dec 25, 2003 | 10:30 PM
  #72
-=TWITCH=-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
They only way this will even matter is if you are injection before the BOV! if you are injectiong into the TB it will not matter.
Chris
Most of use have open loop BOV's so this really isn't a good idea having a highly flammable gas in the engine bay. </TD></TR></TABLE>
Old Dec 26, 2003 | 07:11 AM
  #73
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -=TWITCH=- &raquo;</TD></TR><TR><TD CLASS="quote">They only way this will even matter is if you are injection before the BOV! if you are injectiong into the TB it will not matter.
I can still see it happening. TB suddenly closes blocking the left over propane from going into the Intake manifold. Thus being released by the BOV.
Old Dec 26, 2003 | 07:28 AM
  #74
GimpyAccord's Avatar
So recirculate the BOV... not a big deal to do. I do it on my civic & Talon (even though I have a GM-MAF on it now) because I think BOV sound = annoying. Seems worth it to me to gain major power!
Or at the very least plumb it out of the engine bay.
Old Dec 26, 2003 | 07:38 AM
  #75
ladysman's Avatar
Default Re: Anyone runnuing PROPANE INJECTION? (GimpyAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GimpyAccord &raquo;</TD></TR><TR><TD CLASS="quote">So recirculate the BOV... not a big deal to do. I do it on my civic & Talon (even though I have a GM-MAF on it now) because I think BOV sound = annoying. Seems worth it to me to gain major power!
Or at the very least plumb it out of the engine bay.</TD></TR></TABLE>
Not that easy to recirculate an HKS SSQV. If you have seen it, post pictures.
