Propane injection?
Old Dec 8, 2003 | 12:57 PM
  #26
Kwuaymaikrup's Avatar
Default Re: Anyone runnuing PROPANE INJECTION? (-=TWITCH=-)
Damn...that is cheap!!! As asked above, do you know if you can run a smaller bottle or nitrous type bottle with this setup?
Old Dec 9, 2003 | 09:06 AM
  #27
-=TWITCH=-'s Avatar
Default Re: Anyone runnuing PROPANE INJECTION? (Kwuaymaikrup)
Yes you can rune a smaller bottle! I run a 5lb bottle they make a 2.5 im pretty sure. The best place to look for propane bottles is a RV camper store they sell all kinds of weird size tanks etc.
Old Dec 9, 2003 | 11:53 AM
  #28
-=TWITCH=-'s Avatar
ttt
Old Dec 9, 2003 | 02:24 PM
  #29
Justin Olson's Avatar
Can you just run propane injection sort of like water injection? Is there a way to base how much propane is injected based on a Map sensor? I think that would be a much more reliable way of doing it.
Old Dec 9, 2003 | 02:27 PM
  #30
boosted92's Avatar
Default Re: Anyone runnuing PROPANE INJECTION? (olsonjus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by olsonjus &raquo;</TD></TR><TR><TD CLASS="quote">Can you just run propane injection sort of like water injection? Is there a way to base how much propane is injected based on a Map sensor? I think that would be a much more reliable way of doing it.</TD></TR></TABLE>
Yes, you inject propane much the same way as you injection alky/water, usually with a hobbs switch. As far as I know right now there is no progressive propane controller, but i'm sure you could rig up a way to use a progressive nitrous controller to control how much flow the solenoid(s) allow.
Old Dec 9, 2003 | 03:14 PM
  #31
-=TWITCH=-'s Avatar
Default Re: Anyone runnuing PROPANE INJECTION? (boosted92)
Actually, there are some progressive controller kits out on the market! They are quit expensive but they are made.
here is a kit that offers a progressive controller!
http://www.dieselperformancepr...#feat
THe price Powershot 2000™
$649.99 without tank!
Old Dec 9, 2003 | 03:40 PM
  #32
stickshiftt's Avatar
do you know of any people useing it one a supercharger, like jrsc. it would have to go through the blower of the supercharge. if you know of people useing it on that how did it work, good, bad.
Old Dec 9, 2003 | 04:03 PM
  #33
-=TWITCH=-'s Avatar
Default Re: (stickshiftt)
Yes I have! it works just fine propane is injected in a gaseous form no harm to the blower~
Old Dec 9, 2003 | 04:17 PM
  #34
int3gra's Avatar
Default Re: (-=TWITCH=-)
stop yellling at us!!!!
Old Dec 9, 2003 | 06:58 PM
  #35
Default Re: (int3gra)
Cool, I would rather use methanol injection over propane. Meth definately has the octane but it also absorbs a lot of heat.
Old Dec 9, 2003 | 07:22 PM
  #36
-=TWITCH=-'s Avatar
Default Re: (olsonjus)
Methanol is corrosive and it does not get a long well with aluminum. It’s a huge pain to flush your system all the time. And water absorbs more heat than Methanol
Old Dec 9, 2003 | 08:06 PM
  #37
totalimpact's Avatar
What do ou think about these guys -
http://www.welshtec.com/page0010.html
Are there better or worse kits out there?
Old Dec 9, 2003 | 08:27 PM
  #38
-=TWITCH=-'s Avatar
Default Re: (totalimpact)
looks intresting but there is really no informtaion on how the kit works or operates. How do they fill the propane tank from the side of the car? never seen that kinda fitting before, all the places that fill my tank just fill grill type tanks so it might be a pain to find a place that will that that kinda setup? but like I said there is really not that much info about the kit.
Old Dec 10, 2003 | 09:51 AM
  #39
-=TWITCH=-'s Avatar
ttt
Old Dec 11, 2003 | 10:26 AM
  #40
-=TWITCH=-'s Avatar
ttt
Old Dec 13, 2003 | 04:51 AM
  #41
-=TWITCH=-'s Avatar
ttt
Old Dec 13, 2003 | 09:48 AM
  #42
SuicideSlide's Avatar
So the propane system is always on? Meaning once you start the car the tank is open and running(After you manually open the tank?). The system is always misting propane into your TB? I read that it comes on at a preset amount of boost. So we set it at the boost pressure we want it to come on at. Ie - 10 psi like you said. So before &lt;10 psi we're just using 91 octane? After 10psi, 110+ octane?
very interesting stuff...
thanks
Old Dec 13, 2003 | 11:28 AM
  #43
nevin's Avatar
so do you have the bottle mounted in the trunk(sideways or vertical?) and have a rubber hose running the the engine bay?
Old Dec 13, 2003 | 11:37 AM
  #44
boosted92's Avatar
Default Re: (nevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tur*bLu &raquo;</TD></TR><TR><TD CLASS="quote">So the propane system is always on? Meaning once you start the car the tank is open and running(After you manually open the tank?). The system is always misting propane into your TB? I read that it comes on at a preset amount of boost. So we set it at the boost pressure we want it to come on at. Ie - 10 psi like you said. So before &lt;10 psi we're just using 91 octane? After 10psi, 110+ octane?
thanks</TD></TR></TABLE>
You can setup the propane to come on at a predetermined boost level, use it as a fuel source with nitrous, or if you wanted to try using propane to run a high compression motor on pump gas I guess you could use a WOT switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin &raquo;</TD></TR><TR><TD CLASS="quote">so do you have the bottle mounted in the trunk(sideways or vertical?) and have a rubber hose running the the engine bay?</TD></TR></TABLE>
I mounted my bottle vertically and I replaced the rubber hose with steel braded line, and ran that to my engine bay.
Old Dec 13, 2003 | 11:52 AM
  #45
nevin's Avatar
Default Re: (boosted92)
Does it matter how you mount it? and you said its injected into the tb, would that be before or after the plate? Is that the best place to have it or could you have it setup to inject into a charge pipe before the tb or maybe injected into each runner like direct port? Where would be the best place to have it, cause I was reading on how you have to recirculate the bov so you dont shoot out propane into hot engine bay components..
Old Dec 13, 2003 | 01:20 PM
  #46
boosted92's Avatar
Default Re: (nevin)
I have 2 bovs one mounted after each turbo, still running open loop, and the propane nozzle I mounted about 24 inches downstream from the throttle body. I'm not sure if you can mount the bottle horizontally, you could check with OGS or a tank manufacturer.
Old Dec 13, 2003 | 01:39 PM
  #47
-=TWITCH=-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">I have 2 bovs one mounted after each turbo, still running open loop, and the propane nozzle I mounted about 24 inches downstream from the throttle body. I'm not sure if you can mount the bottle horizontally, you could check with OGS or a tank manufacturer.</TD></TR></TABLE>
You cannot mount the bottle on its side. They make a speacail kind of bottle that can be used horizontally but your average BBQ propane tank cannot. The reason being is it will inject liquid propane into your engine, not a good idea. You want to inject the Vapor!
Old Dec 13, 2003 | 02:01 PM
  #48
nevin's Avatar
Thanks, makes sense.
Old Dec 14, 2003 | 06:54 PM
  #49
-=TWITCH=-'s Avatar
Default Re: (nevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, makes sense.</TD></TR></TABLE>
Old Dec 14, 2003 | 07:09 PM
  #50
zomart's Avatar
uh.. i'm not sure, but is propane flammable? what happens if you get in an accident with this stuff in the trunk? it seems like it would be flammable since it burns in your engine...
