Project over heating.... any suggestions?
Old Aug 28, 2007 | 09:56 PM
nabin's Avatar
Default Project over heating.... any suggestions?
My project is having problems.
I started with a 1995 gsr motor that needed new valve seals. I had a 2000 head from a good running motor that i swapped onto the 1995. while swapping the head, i used a cometic head gasket and ARP head studs (this set-up was supposed to soon be turboed). Anyway, with those mods, and everything else normal, the car over heats. It over heats quickly - in about ten minutes.
Now if i remove the thermostat, the car will not overheat. I assumed that it was a a bad thermostat so i went to autozone and got another. the old thermo was tested in water and for sure works and opens. So, Im still having the same problem. I did a compression test as well and came up with good numbers.
Can anyone help me? steer me in the right direction?
Old Aug 29, 2007 | 11:40 AM
nabin's Avatar
Default Re: Project over heating.... any suggestions? (nabin)
oh cmon honda-techer....some one has gotta have a suggestion
Old Aug 29, 2007 | 12:34 PM
batboyvaj's Avatar
make sure your fan is working and wired corectly
Old Aug 29, 2007 | 01:52 PM
Mr.Death's Avatar
Default Re: Project over heating.... any suggestions? (batboyvaj)
Air in the cooling system?
Warped head?
Improperly installed headgasket?
Old Aug 29, 2007 | 04:00 PM
nabin's Avatar
Default Re: Project over heating.... any suggestions? (Mr.Death)
both heads were off running motors and removed properly. the head on this motor was installed in the correct sequence and torqued to correct speks. torque specs were double checked while installing.
Fan is wired correctly, does not switch on on its own, instead i have it hardwired to always be on, this is only because i cant figure out what going on with the overheating problem. perhaps this plays a part, but not sure how yet.
If the head were warped would i still get get comp numbers? how could i tell it was warped? any other suggestions?
Old Aug 29, 2007 | 04:17 PM
boostmywankle's Avatar
i would take the head back off, get an oem headgasket, check the head for straitness. and then go from there. It only takes a few hours to do a headgasket so why not? i just dont see it being anything else but the head install, since you said u swapped them because of the valve seals. keep us updated though
Old Aug 29, 2007 | 05:03 PM
nabin's Avatar
Default Re: Project over heating.... any suggestions? (boostmywankle)
soiunds like a plan. just take the head up to a machine shop? honestly ive never gotten one checked out before.
Old Aug 29, 2007 | 06:11 PM
Urugly's Avatar
from recent experience if head comes back as straight then it is probably a bad head gasket.
Word around town is Cometic (which I have and have heat issues with) is not the greatest. Get a GE head gasket.
Then make sure you bleed the cooling system properly after that.
The last thing I did that actually helped, and this is worse case change radiator. My old Fluidyne was not flowing properly and therefore couldn't cool the car properly. When I got my Koyo, temps. are great!!
Good luck.
Old Aug 29, 2007 | 08:55 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nabin &raquo;</TD></TR><TR><TD CLASS="quote">Anyway, with those mods, and everything else normal, the car over heats.</TD></TR></TABLE>
That sounds all too familiar. Check this out and see if it applies to you: https://honda-tech.com/zerothread?id=2083018
Old Aug 29, 2007 | 10:30 PM
nabin's Avatar
Default Re: Project over heating.... any suggestions? (Dunc)
can a block warp?
Modified by nabin at 7:10 PM 8/30/2007
Old Aug 30, 2007 | 10:11 AM
nabin's Avatar
will a block warp? not easily right?
since the car will not heat up without thermo and will heat up with thermo, but thermo is good. what would be the problem? the head gasket? or water pump?
Old Aug 30, 2007 | 02:22 PM
HickamHatch's Avatar
sounds like it could be the waterpump man.
Old Aug 31, 2007 | 01:48 PM
nabin's Avatar
Default Re: Project over heating.... any suggestions? (HickamHatch)
im getting a new water pump from oreillys tommorow, if that doesnt fix it, off comes the head.
also to add - my fan does not come on on its own, i have to have it hard wired in. would this be a faulty switch by the thermo? if the thermo opens in boiling water it functions properly, correct?
WKLTTRANSPORT
Honda Civic (2001 - 2005)
Mar 2, 2016 01:44 PM
hondamike89
Feb 28, 2009 01:40 PM
slomovr
Jan 16, 2009 12:28 PM
cstay
Apr 11, 2004 08:27 PM
