programming a PRofec A
Old Jun 9, 2003 | 07:18 PM
kaj's Avatar
kaj
Default programming a PRofec A
went through the P1 and P2 learning curves. here are my problems:
*no mater what "offset" i dial in, the profec never reads more than 5psi on it's "boost gauge" no matter what offset i program and no matter what boost setting i use.
*no matter what boost setting i use (even if i put it up to 1.0 bar) i can only get 8.5psi on my boost gauge.
can anyone tell me how to reset the unit to relearn p1 and p2 again?
Old Jun 10, 2003 | 05:33 AM
Brad's Avatar
I believe you just hold the power switch down until the p1 shows up. I think you hear a beep too.
Old Jun 10, 2003 | 08:36 AM
kaj's Avatar
kaj
Default Re: (Brad)
i'll try that. i think i already did.. not sure. but will try again. thanks
Old Jun 10, 2003 | 11:18 AM
ykracing's Avatar
Default Re: (kaj)
to reset it, you have to hold the power button for a WHILE.... finally p1 will show up.
(it seems like it will never do it, but keep holding the button til it does)
Old Jun 10, 2003 | 11:20 AM
ykracing's Avatar
Default Re: (trboCIVIC&WRX)
oh yeah,
check your hose layout, that could be one of your problems.
And check to mak sure your dip switches are set properly.
Old Jun 10, 2003 | 05:04 PM
kaj's Avatar
kaj
yeah, i've triple checked the hoses.
it seems i get 9lbs of boost in the day and only about 6-7 after it warms up. weird. i knew i got hosed when i bought this thing!
kcjohnnyboy
Dec 1, 2003 02:38 PM
boostdB16a
Jul 9, 2003 04:48 PM
CRVRX
Nov 16, 2002 08:03 PM
b18tdelsol
May 18, 2002 11:46 AM
