problems w/motor. what should i do??
Old Nov 5, 2003 | 08:13 AM
crx1856's Avatar
Default problems w/motor. what should i do??
here's my setup.
ge sleeved b16,weisco 84mm pistons,revhard 2c kit,hondata s200,p28,550 injectors,255 walbro pump,3 angle portflow head,95 gsr cams. i bought this motor pre built from ib. after the break in, i had it leak down and cr tested with poor results so i had the block rehoned and re did the rings. now after the second break in, it looks like i have one piston that is 20psi off from the others and has a leakdown of 12%. should i just re do the rings again with a fresh hone or will the piston to wall clearance be too much. will boring the block to 84.5 with new pistons be a problem on this block? i'd rather not buy new pistons but i will if i have to. i don't want to go through this again. what do you guys suggest and what should my piston to wall clearance be and ring gap.
dgie
Jul 9, 2008 09:01 PM
got wide
Sep 4, 2007 03:55 PM
PrinceAli132
Feb 11, 2007 03:10 PM
Robban26
15
Jan 24, 2004 01:31 AM
xteg95
May 3, 2003 04:16 PM
