Problems using standard bore??
Old Nov 5, 2002 | 04:57 PM
ASHY-ELBOW's Avatar
Default Problems using standard bore??
k guys i am hearing diff things about piston slapp ect if u dont have your block bored when upgrading to forged pistons and rods. I recently had my pistons replaced for ctr pistons and rings..all the did was hone the block and my car runs fine. The thing is i wanna know if i would get piston slap upgrading to stcok bore forged pist/rods ...My turbo project is draing the funds already i dont wanna have to remove the whole engine and pay to hjave it bored also i was thinkin $763 piston rod package from race engineering and block guard for 95 bucks ....im not gonna run too much boost 10-12 but i just wanna be safe and i also wanna get rid of these ctr slugs by the way i have 95 gsr
Old Nov 5, 2002 | 05:50 PM
PyroVTEC's Avatar
New User
Default Re: Problems using standard bore?? (1320racing)
You're going to have a lot of blowby if you don't have the cylinders honed again when you put those new pistons & rings in. The rings won't seat properly. I have stock bore SRPs and they slap when cold as well. It has nothing to do w/ what size the bore is, it has to do w/ the silicon content of the particular piston you're working with. Arias, in particular, has been known for more durable pistons, although the downside to this is that they slap a lot.
Old Nov 5, 2002 | 06:35 PM
Jared's Avatar
as long as you did a good hone job you'll be fine, its the h22/23 blocks that need to have new sleeves installed.
Ryhaz
10
Jan 14, 2014 07:57 AM
92cxturbo
May 28, 2009 03:06 PM
Sketch_hs
Feb 4, 2006 10:00 PM
bob16ost
Aug 26, 2003 11:58 AM
KayOs
Aug 17, 2001 11:22 PM
