problems in resevoir tank
Old Nov 15, 2003 | 11:36 AM
reditr's Avatar
Default problems in resevoir tank
Hi guys i am occuring a new problem, i have noticed that after giving it a good spin the car looses power , at free the car want rev up so quickly. After i drive for 5 minutes at a slow rate, the car would come back to normal. I have popped up the hood to check that everything is ok and i have noticed that the resevoir tank was all filled up and some water has been spilled out of it. There are no signs of smoke from the exhaust, no air bubbles in the reservior tank, and no overheating, can somebody give me a clue what is happening here please?
ANY HELP PLEASE?
Modified by reditr at 1:07 PM 11/15/2003
Old Nov 15, 2003 | 12:48 PM
sporkcrx's Avatar
Default Re: problems in resevoir tank (reditr)
Rad cap?
Old Nov 15, 2003 | 01:03 PM
reditr's Avatar
Default Re: problems in resevoir tank (sporkcrx)
what do you mean by rad cap?
Old Nov 15, 2003 | 02:01 PM
99B16Si's Avatar
a bad radiator cap can cause the spring in the cap to open to easily and release some of the pressurized coolant back into the reservoir and it can only hold so much so eventually it will overflow.
Id hate to say it but it could possible be your headgasket. i minor blow to the headgasket will sometimes not even be notice able. a leakdown test will tell you for sure
Old Nov 16, 2003 | 03:25 AM
reditr's Avatar
Default Re: (99B16Si)
OK guys thanks a lot for your help
stupidasso15
21
Mar 23, 2012 07:19 PM
gamakichi77
28
Apr 20, 2010 12:32 AM
ahs2m2
Jul 14, 2008 11:31 PM
WS6Dreams
Dec 5, 2003 12:53 PM
tinkerbell
Mar 28, 2002 06:34 PM
