problems with my fuel system
Old May 15, 2005 | 07:22 PM
s1ngle's Avatar
Default problems with my fuel system
ok, due to my sheer stupidity, please dont ask why, my DSM 450cc injectors saw over 100+ psi of fuel accidentally. Now I got that problem taken care of, but i'm rich all the time now... is there a chance i F'ed up my injectors and theyre stuck open or something? My car is *** slow and guzzling gas, please help!
Old May 15, 2005 | 07:43 PM
Wideopentuning's Avatar
Default Re: problems with my fuel system (s1ngle)
Recheck fuel pressure. You could have a stuck regulator.
Old May 15, 2005 | 09:44 PM
s1ngle's Avatar
Default Re: problems with my fuel system (Wideopentuning)
i dont have a stock regulator, and fuel pressure is fine.
edit: i can't read. the fuel pressure regulator isnt stuck as far as i know, my gauge reads normal fuel pressure.
Modified by s1ngle at 6:03 PM 5/16/2005
Old May 16, 2005 | 09:03 AM
s1ngle's Avatar
bump, help!
Old May 16, 2005 | 09:06 AM
SOHC_MShue's Avatar
I guess they could have gotten stuck if it was running fine before.
Old May 16, 2005 | 03:31 PM
s1ngle's Avatar
Default Re: problems with my fuel system (SOHC_MShue)
bump, is there anything else that could have gone bad?? i'm about to go pick up some new injectors, and if theres anything else i can check id like to do it!
Old May 16, 2005 | 03:45 PM
s2kdre's Avatar
whats your fuel psi at?
Old May 16, 2005 | 03:46 PM
s2kdre's Avatar
Default Re: problems with my fuel system (jdmhonda)
if they were stuck open the car wouldnt run at all
Old May 16, 2005 | 07:21 PM
s1ngle's Avatar
well i got a new set of 450s in there, same exact problem. a/f gauge pegged at rich, car not running well. Maybe its not even running rich, i just have no idea whats going on. whats the best way to approach this
my fuel psi is fine, 48 psi.
Old May 16, 2005 | 07:31 PM
lkailburn's Avatar
bump this ish up for my buddy. lets get some collective thoughts here and fix this problem!
go try those plugs and report back
Old May 16, 2005 | 07:41 PM
s1ngle's Avatar
Default Re: (lkailburn)
plugs are not the problem, tried a different set.
the.hamburglar
Mar 27, 2015 07:58 AM
ken2830
Nov 3, 2009 09:28 AM
Nascarhatch
Mar 19, 2009 11:39 PM
dominate9
Oct 14, 2003 09:48 AM
