problems fine tuning profec B
Old Jan 31, 2004 | 09:45 PM
ATS*Mark's Avatar
OG triple OG
Default problems fine tuning profec B
ok , i guess this is boost spike , im tryin to get my controller to 8 lbs and it will go up to like almost 9 , then back down to like 7.9 right away...then as i get up in the rpms it will drop back down slowly to like 6.5 lbs...i cant get this thing tuned right ,i tune it with 4th gear pulls. and when i think ive got it right , ill happen to look at it when im in 2nd or 3rd and it will be in the 6's . its ****** anoying. can anyone help me?
Old Jan 31, 2004 | 10:05 PM
Adi Radoncic's Avatar
On Fire!
Default Re: problems fine tuning profec B (Hella_JDM)
Are u sure this is a boost controller related problem??
Did you just switch from a manual one?
There isn't really much to the profec b, just turn ****, set to desired boost level and it works.
Old Jan 31, 2004 | 11:39 PM
ATS*Mark's Avatar
OG triple OG
Default Re: problems fine tuning profec B (newgsr)
no this is my first controller..... i did the internal wastegate "mod" and it was fine , then i put it back to stock..... i cant seem to get this thing to even out.
Old Jan 31, 2004 | 11:55 PM
FBP Si 2000's Avatar
Is the internal wastegate "mod" the one in the instructions? Is this with the Spec II?
Old Feb 1, 2004 | 12:09 AM
ATS*Mark's Avatar
OG triple OG
Default Re: problems fine tuning profec B (FBP Si 2000)
the internal wastegate mod is where you turn the actuator screw in to up the boost , people do that who dont have boost controllers that want to up the boost
yes this is the spec 2
Old Feb 1, 2004 | 12:13 AM
MiraiZ's Avatar
try playing with the balance ****
Old Feb 1, 2004 | 12:16 AM
Ah...I see what you mean now.
Old Feb 1, 2004 | 07:26 AM
ATS*Mark's Avatar
OG triple OG
at what boost do you guys run at??? and what is your gain set at and start boost set at????
Old Feb 1, 2004 | 07:39 AM
Quad-Damag's Avatar
Default Re: problems fine tuning profec B (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">try playing with the balance ****</TD></TR></TABLE>
He has a SPEC II not the better ones with the ****
Old Feb 1, 2004 | 08:15 AM
int3gra's Avatar
Default Re: problems fine tuning profec B (Quad-Damge)
im just guessing here, but could it be u might need a different color spring in your wastegate?
Old Feb 1, 2004 | 08:29 AM
Silverbeast's Avatar
Make sure you have taken the default 10% GAIN out first.
Then go from there.
I had a .4 bar spring and was running very steady at .8 bar all day with the Spec II. There isnt a single problem with the controller!
Old Feb 1, 2004 | 09:05 AM
GaDawgs's Avatar
you might have a problem elsewhere. i had boost creep bad form 8psi spring with no controller it creeped to 12psi. i had a bad exhaust leak from a crack in the back of my manifold. i had to mig weld all the cracks up and now it will steadily boost 8 psi. this might not be your problem but this is what i've experienced with boost creep problems.
Old Feb 1, 2004 | 11:00 AM
egturbo's Avatar
my profec b never had boost spikes and i turn it up and down all the time.
Old Feb 1, 2004 | 12:59 PM
B18bEK's Avatar
dude i had the same problem.. my boost was spiking like crazy and my low boost option didn't even work for me. i got rid of that **** and got the turbo xs manual boost controller, no boost spike and i love it
Old Feb 2, 2004 | 01:32 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (B18bEK)
its wierd tho , cause it will go like a pound over target boost , then come back down , but i cant get a steady boost with it
Old Feb 2, 2004 | 01:52 PM
Default Re: (Hella_JDM)
have you touched the start boost at all?
Old Feb 2, 2004 | 02:53 PM
B18bEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">its wierd tho , cause it will go like a pound over target boost , then come back down , but i cant get a steady boost with it</TD></TR></TABLE>
you should have seen my dyno plot with that profec B. it went crazy, we had it set at like 10 psi and it was bearable. when we tried to go up just to 11psi, it went crazy and was creeping to 1 bar +. the option of high boost / low boost is great, but the mbc has worked best for me (performance wise)
Old Feb 2, 2004 | 04:22 PM
ATS*Mark's Avatar
OG triple OG
ya i need to figure this thing out
integraboosted
Jun 23, 2005 11:59 AM
Mad Cow
Feb 24, 2005 06:12 AM
SilverLudeSi
Feb 23, 2003 03:31 PM
teamrocket si
Feb 10, 2002 02:27 PM
