problems with DRAG turbo kits?
Old Jun 19, 2003 | 08:29 AM
95stangkillah's Avatar
Default problems with DRAG turbo kits?
just got a DRAG turbo kit put on my B18C1 engine. I'm running 450cc injectors and a APEX safc. the car is hard to start sometimes. my friend told me to get hondata tuning done. any stories and experiences you want to share?
Old Jun 19, 2003 | 08:32 AM
B18c1turboedEK's Avatar
Default Re: problems with DRAG turbo kits? (95stangkillah)
From what i understand,its hard to start cars with 450..Thats just the way turbos go!!
Old Jun 19, 2003 | 08:34 AM
ebp 99 si's Avatar
me and a friend of mine just put mine in over the weekend and i'm running the fmu and vafc till my hondata comes in next week
i haven't had any problems yet
i'm still running stock injectors till i get the hondata in then i get to put my 880cc's on......that will be fun trying to trim them down
boost comes on nice and strong and is smooth too
cops dont like open downpipe though..i need to get my exhaust welded up
Old Jun 19, 2003 | 08:46 AM
TurbodCX's Avatar
Default Re: problems with DRAG turbo kits? (ebp 99 si)
This things screams guys.(I am the freind who did it )
I was thoughroughly impressed by the vaccum to boost transfer and the yank up top is nice.
I just didnt like having to shave the damn block!!! what a pain in the ***.!
now just to tune the hondata on 880's
Brian
Old Jun 19, 2003 | 08:57 AM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebp 99 si &raquo;</TD></TR><TR><TD CLASS="quote">cops dont like open downpipe though..i need to get my exhaust welded up</TD></TR></TABLE>
are you having any problems with boost spike/creep with the open DP???????
Old Jun 19, 2003 | 09:20 AM
mstsh80's Avatar
i have no creep at 6 lbs, it did creep at 8 lbs though,and my kit did not fit for ****, great power though
Old Jun 19, 2003 | 09:29 AM
psileepR's Avatar
New User
if u have dsm injectors then hard starts when the car is warm is normal
Old Jun 19, 2003 | 09:32 AM
sivik2nr's Avatar
are you guys using the resistor box like your 'supposed' to? That's what i've heard anyway... it could cause problems if you don't use it.
Old Jun 19, 2003 | 10:06 AM
1point7T's Avatar
I have no problems starting..
I'm using dsm 450cc injectors and the uberchip
I used radio shack resistors..
however, the drag kit is a pain in the ***, and I won't recommend it to anyone..
definitely not a "bolt-on" kit..
Old Jun 19, 2003 | 11:26 PM
ebp 99 si's Avatar
Default Re: problems with DRAG turbo kits? (1point7T)
no creep at all
wastegate spring is set at 9lbs and it does fine
hopefully it won't creep when i hook up the avcr
i've heard good and bad things about the avcr
Old Jun 19, 2003 | 11:40 PM
MiraiZ's Avatar
Default Re: problems with DRAG turbo kits? (Civtek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civtek &raquo;</TD></TR><TR><TD CLASS="quote">if u have dsm injectors then hard starts when the car is warm is normal</TD></TR></TABLE>
That must be either a Hondata thing or improper tuning because I have never had this problem...the car idles and starts like stock.
Old Jun 20, 2003 | 03:50 AM
Overblown-Teg's Avatar
I think its more from old dirty injectors. Get them things cleaned and inspected before you run them.
Old Jun 20, 2003 | 03:52 AM
Accord94DX's Avatar
never had this problem with dsms. let the safc boot up before starting the car.
Old Jun 20, 2003 | 06:11 AM
Mase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1point7T &raquo;</TD></TR><TR><TD CLASS="quote">
definitely not a "bolt-on" kit..</TD></TR></TABLE>
hrmm mine bolted on quite nicely, the only thing i changed was the oil return line, which was cheap, and had to weld flanges to the downpipe. to me i dont think it could have gone easier
Old Jun 20, 2003 | 06:33 AM
tony1's Avatar
Default Re: problems with DRAG turbo kits? (Koticcivic4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Koticcivic4u &raquo;</TD></TR><TR><TD CLASS="quote">From what i understand,its hard to start cars with 450..Thats just the way turbos go!!</TD></TR></TABLE>
Umm, no, that's not the way turbo's go. That's the way it goes when you cut corners....
shadow103rd
Dec 14, 2003 04:39 PM
blacksheep
Mar 16, 2003 08:00 AM
aesthetics82
May 20, 2002 02:28 PM
highmilehatch
Oct 6, 2001 06:18 PM
Ben Huynh
Jul 28, 2001 02:36 AM
