hondata 2b plug and play...
Old Oct 6, 2001 | 12:26 PM
highmilehatch's Avatar
Default hondata 2b plug and play...
Hi. I read somewhere on this forum that you can purchase a hondata stage 2b already premapped for a drag turbo with 440cc injectors. My problem is I have a MP tubular manifold with a slightly larger turbo. My question is. If I were to purchase a hondata stage 2b, would I be able to go out and boost right away? Or would the map for the drag turbo be insuffiecient for my setup? Would the hondata adjust fuel and timing accordingly or would I have to get to a hondata tuner/dyno? I'm exploring my options right now. My current hatch was in an engine fire and I still have sentimental value for the eg and would like to get a light little cx and swap my stuff and make it nuts fast. Buuut, I like the idea of a rear wheel drive 240 sx with a FACTORY turbo sr20det. Reliability is key here as I do not have another car. So if you guys know whatsup let me know, thanks.
[Modified by turboeg, 1:27 PM 10/6/2001]
Old Oct 6, 2001 | 01:22 PM
dragonsmp's Avatar
New User
Default Re: hondata 2b plug and play... (turboeg)
I too want to know about the Hondata 2b, is it already mapped for a Drag kit w/ 440 injectors?
Old Oct 6, 2001 | 01:39 PM
Mikex25's Avatar
New User
Default Re: hondata 2b plug and play... (dragonsmp)
Dragonmp you decided not to sell your car?
Old Oct 6, 2001 | 02:18 PM
Hondata's Avatar
One of the maps our dealers can provide is premapped for a 9:1 GSR with 440s and drag turbo running 60 psi fuel pressure. It is lkely to be far better as a starting proposition than additional injector controllers and FMUs but for safety it must checked with a wide band A/F meter.
Old Oct 6, 2001 | 06:18 PM
Double 06's Avatar
New User
Default Re: hondata 2b plug and play... (Hondata)
doug do any of you tuners have a program for a turbo R @ 6-8psi? I heard there is a shop in greensboro that called turbotune, is he a legite hondata tuner, or someone that just bought stage 4? I know you said there is a place in columbia, i need more info,
thanks
civic-97-si-nx
Dec 9, 2004 12:35 PM
NJTurboCivic
Jan 15, 2004 11:03 AM
JDM_EH2
Jun 3, 2003 11:53 AM
karmannghia
Mar 17, 2002 01:39 AM
Etylorcen
Oct 29, 2001 02:12 PM
