Problem with sleeved B18C6 running on GT3076
Old Feb 24, 2019 | 10:21 AM
Daffy_ed9's Avatar
Default Problem with sleeved B18C6 running on GT3076
Gents,
I'm from Germany and currently facing second time the same issues.
Maybe u have got an idea where to search for:
Specs:
B18c6 with sleeves 82mm
Wieso low comp pistons
Eagle rods
ARP rod / head studs
Garrett GT3076 turbo
Car is doing almost 420 hp and runs pretty strong.
After 4k km the first engine started to smoke blue and consume oil.
First inspection showed a pressure drop in cylinder 3 cause of wear in the sleeve.
Engine was rebuilt and got oversize pistons and was bored / honed
In Addition a new Honda oil pump and new oil squirters were installed
2k km after the rebuilt the same issue occurred again.
There is massive wear on one of the piston making the p2w clearance pretty wide.
Nothing fancy happened, even the Videoband did not recognize anything strange.
What would u search for in the first step?
Video can be found on this link:
Link
Old Feb 24, 2019 | 02:04 PM
TheShodan's Avatar
Moderator
Default Re: Problem with sleeved B18C6 running on GT3076
Originally Posted by Daffy_ed9
Gents,
Specs:
Eagle rods
Link
Are you following manufacture piston/ wall clearance specs? What are you doing for proper engine break -in? Fast break-in or slow break-in method?
what's the purpose of the car? This looks like engine assembly issue
Old Feb 24, 2019 | 05:33 PM
Txdragon's Avatar
Cylinder wall problem, rebuild, same problem again.. Static variable here: crankshaft. Check main and rod journals for #3 I bet something is out of round causing the piston to beat the **** out of that cylinder
Old Feb 25, 2019 | 12:32 AM
1HGEJ2's Avatar
Gents,
Specs:
Eagle rods
Link
Wer hat den Motor abgestimmt? und welchen lambdawert bist du gefahren unter vollast? was war kolbenspiel?
Old Feb 25, 2019 | 10:37 AM
Daffy_ed9's Avatar
piston 2 wall clearance was set to 0.0035
interesting point with the crankshaft,
crank was only polished in machine shop, maybe sth is wrong on the crankshaft
Old Feb 25, 2019 | 12:44 PM
TheShodan's Avatar
Moderator
not if it was just a polish. Did your p2w cleanse match with piston manf. Spec or similar? You never named the manf. Of the piston
Old Feb 26, 2019 | 12:41 AM
1HGEJ2's Avatar
Is matze from neptune ur tuner?
Old Feb 26, 2019 | 10:17 AM
Daffy_ed9's Avatar
Those are wiseco pistons, so the p2w clearance is within their spec
I will remove the crank and rod to get them checked in a mashine shop
Old Feb 26, 2019 | 12:06 PM
Txdragon's Avatar
Try to post up pictures of your main and rod bearings for the #3 journals.
Old Mar 3, 2019 | 01:24 PM
Txdragon's Avatar
Any update on this?
Old Mar 6, 2019 | 01:09 AM
Daffy_ed9's Avatar
engine is going to be pulled on friday.
Will update then
Old Mar 6, 2019 | 01:15 AM
Txdragon's Avatar
Will update then
I had not thought about it at first, but, did you use the same rods from the first time? After you rebuilt. May be a problem with rod 3. Beat up pin bushing, rod bent/warped. If you got new ones and that same problem happened, I'd still stand on the crankshaft then.
92boostedgsr
Jun 23, 2007 09:47 AM
the.hamburglar
Jun 20, 2006 09:34 PM
mylsspecteg
May 21, 2006 03:22 PM
Forrest Gump 9
Jan 30, 2004 12:37 PM
1337 Si
Jul 6, 2003 09:04 PM
