Problem: maybe possible blown headgasket...Need your input.
Old Nov 1, 2002 | 08:07 AM
  #26
espanol's Avatar
Default Re: Problem: maybe possible blown headgasket...Need your input. (Flamenco-T)
update: pull the head off, * crossign my finger * that is the only problems
Did you figure it out yet? Good luck..
Old Nov 2, 2002 | 02:46 AM
  #27
wHOAlly's Avatar
eventhough the head never came off ? I took the studs out, and at that point the weight of the head is the only pressure that held it to the block
yea, but by loosing the head studs, then retorqin them, u probably broke the seal between head/gasket/block and allowed it to seep, especially if u didnt drain the coolant...when u retorq u dont undo it, u just torq it down more.
Old Nov 2, 2002 | 02:56 AM
  #28
Mase's Avatar
Ill update for stan...,hope you dont mind stan..hehe he had more problems He cracked his radiator, however, he didnt bitch to me tonight about the leaking problem, so i hope it was fixed by swapping out the head gasket.
So if anyone in SO CALI has a used radiator, STAN WILL BUY IT.
But hey, you still have 6 days to fix the bugs, right?
Old Nov 2, 2002 | 07:35 AM
  #29
NeXtLeVeL_TyPe_R's Avatar
-Flamenco T-
go to this thread maybe it will help you
https://honda-tech.com/zerothread?id=195468
What happened with me was my friend helped my take the timing cover plate off and the back plate on the block off and he unscrew one of the bolts from the wate pump.
Its a long shoot by hey you never know
Old Nov 2, 2002 | 07:53 AM
  #30
Jared's Avatar
Default Re: Problem: maybe possible blown headgasket...Need your input. (NeXtLeVeL_TyPe_R)
Let us know how it turns out after you pull the head. I'm very confident that your loosening the studs killed your block to head seal. When retorquing bolts, you tighten them to the new torque, you never back them off and lose the seal. Replacing the headgasket will solve your problem. You said your headgasket was copper? cover it thoroughly with copper seal, add some honda bond around the water ports and install. let the engine warm up, then cool off again and make sure you have no leaks, then retorque the head again(but do not remove the nuts, just retorque them).
Old Nov 2, 2002 | 09:25 AM
  #31
POLLO's Avatar
Default Re: Problem: maybe possible blown headgasket...Need your input. (Jared)
It's 1:30 pm E.S.T.... any updates ?
Old Nov 2, 2002 | 06:27 PM
  #32
Flamenco-T's Avatar
everything was done last night...car runs great, UNTIL, I punctured the radiator when putting AC fan back on....
I was more laughing on these crazy stuff that is happening...it seems so funny...but I am getting a radiator tmw...
other than that, gasket was very wet...the fact that the gasket was wet may have contributed a channel to get everything leak out...like someone mentioned above...
but I ran it for 30 minutes while filling the rad with water....and NO LEAKS...so for that I am happy...
I torqued the studs to 70 Ft/LB with ARP Moly Lube...I'll let it go to 10 cycles and re-torque it again...
thanks for the support guys..
stan
Old Nov 2, 2002 | 06:51 PM
  #33
Tomakit's Avatar
Glad you're back on the right track.
Tom
CivicxTree754
Oct 13, 2011 10:28 AM
94integragsr
Jun 3, 2006 11:13 AM
b16 matt
Sep 23, 2004 11:19 AM
Flamenco-T
Oct 31, 2002 10:40 PM
