Problem: Compression Done, now what
Old Nov 19, 2002 | 04:50 PM
DeepSi's Avatar
Default Problem: Compression Done, now what
Problem:
I have been having faint grayish/white smoke coming out from my exhaust, only under boost.
Things i have done:
1. I got a compression test done on my car and it came out with nice numbers:
240 | 235 | 235 | 230
#4 #3 #2 #1
thank god, i had a lump in my throat the entire test.
2. Took off piping, no oil in piping what so ever.
So what step i should i take next? i talked to a guy that runs a shop, and is somewhat familiar with turbos and told me to check my downpipe for oil, to see if the oil seals are bad.
Does anybody else know what should do?
thanks
-deepsi
Old Nov 19, 2002 | 05:16 PM
noel's Avatar
Default Re: Problem: Compression Done, now what (DeepSi)
I can't help ya out but I'm curious, why is it that a the #1 cylinder always seems to loose compression first? Does it have anything to do with the type of manifold?
Noel
Old Nov 19, 2002 | 05:25 PM
ekb18c's Avatar
Leakdown test!
Old Nov 19, 2002 | 05:27 PM
PrecisionH23a's Avatar
Default Re: Problem: Compression Done, now what (ekb18c)
Leakdown test!
yes, compression tests dont mean **** in my experience...
Old Nov 19, 2002 | 05:40 PM
AVATAR's Avatar
Default Re: Problem: Compression Done, now what (GudeH23a)
I dunno about comp. tests not meaning ****, but I would do a leakdown test for sure. Usually the "hot" cylinders in the B16A2s were in cylinder 3. Are you just running the blue box, or did you get the Hondata tuned?
[Modified by AVATAR, 2:41 AM 11/20/2002]
Old Nov 19, 2002 | 06:06 PM
DeepSi's Avatar
Default Re: Problem: Compression Done, now what (AVATAR)
I got the Hondata tuned, and evrything runs nice and smooth. I have been trying to get a leakdown test, but all the automotive and performance places i go, nobody does leakdown tests.
Does anybody know a place in the bay area that does leakdown testing?
thanks
-deepsi
climb_on
Jul 29, 2007 03:40 PM
JDMtype Eg6
Jul 14, 2007 02:31 AM
John.
Jun 12, 2006 08:45 AM
Azcheron
Jun 23, 2005 09:34 PM
mafay2
Nov 11, 2004 07:34 PM
