Problem after fuel pump install???
Old Feb 14, 2003 | 07:25 PM
flat-blk-HB's Avatar
Default Problem after fuel pump install???
ok I know this should and proably will not be from installing the pump. but here we go, me and my friend just installed a walbro 255 high pressure in his 96 DX with a greddy kit with "mini-me" set-up. Well the thing is the car was running great for like 5 mins then it started to over heat????? It is like the car will get hot then you crank the heater on full blast and it cools down drastically. Well he drove the car from work then we installed the pump and then it started to do this. The car ran fine no problems with over heating or anything before. We changed the Thermostat and that was not the problem still over heating. Then we did one of those check the head gasket while the car is running things. You know pull the cap off the radiator and watch the coolant. It was perfectly still only moving little bits. Well we added coolant too and it took some not too much and it still over heats. We are going to mess with it more tomorrow morning and I was just looking for some ideas to check.
Also when a water pump goes bad you know it right? It will leak water like crazy and make noises right?
Any ideas are greatly appericated thanks,
Brandon
Old Feb 14, 2003 | 07:53 PM
Doodoo's Avatar
Default Re: Problem after fuel pump install??? (flat-blk-HB)
The water pump doesn't always leak 'like crazy'. Sometimes you can see where the water has dried near the pump. Sometimes it doesn't leak until it idles for awhile. Be on the look out for puddles.
Old Feb 14, 2003 | 08:07 PM
Default Re: Problem after fuel pump install??? (Doodoo)
Cool we will check that tomorrow too.
Any other ideas???
Old Feb 15, 2003 | 06:28 AM
Any other ideas???
Old Feb 15, 2003 | 06:45 AM
b16ahybrid's Avatar
Does the fan kick on?
Old Feb 15, 2003 | 06:47 AM
Default Re: Problem after fuel pump install??? (b16ahybrid)
Yeah at oddball times when the car has already got hot. So we ran a hot wire straigt to the fan from the battery and test drove after cooling down and still got hot.. ..Well I am on my way over there to check things out again, Hopefully we will find out what the hell.
Old Feb 15, 2003 | 08:18 AM
We swapped out fuel pumps back to stock and the damn thing runs good. Not getting hot or anything.
gstrudler
Jul 28, 2009 09:22 PM
Boognish
Jul 24, 2005 06:03 PM
Autoworks
Apr 26, 2005 03:43 AM
Autoworks
Apr 24, 2005 07:43 AM
cadougherty_67
Mar 29, 2005 06:21 PM
